power commander help for a 929 - Honda Motorcycles - FireBlades.org
post #1 of 13 Old 12-16-2012, 4:02 PM Thread Starter
Hi all hope somebody can help ,i recently bought a 954 power commander 111r for my 929 but cant exchange map properties to send a map , in fact i cant even send a 954 map to the 954 power commander.i am using a 9v battery and usb serial cable to set the unit up but it wont let me send maps .i have tried manually transfering data from a 929 map onto the 954 display but no luck .the unit powers up and i can use the adjust buttons so it obviously works .any help most appreciated
brendan_mills is offline
post #2 of 13 Old 12-16-2012, 8:51 PM
Re: power commander help for a 929
What do you mean by "no luck"?
You can type new values into all of the boxes?
Are you saving the 929 map after you change the values to match the 954 map?
post #3 of 13 Old 12-17-2012, 2:24 AM Thread Starter
Cheers bladeracer hope between us i can get this done,when i plug the unit in i get a display box were all my values should be but they are blank no figure in them at all even if i change the port .then when i try to copy all the values off a map from power commander into it there is not enough space it only has enoughblocks for up to 7500 rpm ,thought it would of got bigger as it got full to allow you to copy the whole lot but cant do it.just wandering if the lead to pc or 9v battery supply is to blame.the unit lights up and i can adjust the settings lean to rich whilst plugged in and thats about it.the page it displays is blank and i cant replicate the one i need.it wont let me send a 954 map of any kind even though its for a 954 .bit of a head fry soz mate
post #4 of 13 Old 12-17-2012, 2:42 AM
Take a screenshot of the 929 map you want to use.
Open the 954 map that you want to alter.
Type all the 929's values into the 954 map.
Save the map.
Send the map to the PC.
post #5 of 13 Old 12-17-2012, 4:20 AM Thread Starter
I will try that but if i cant send a 954 map supplied by power commander to the 954 unit so thats y i thought something must be wrong with the data cable or something.my friend spentan hour and a half with me trying to do it and he runs a pc shop so no stranger to a computer and he couldnt get a map to send neither
post #6 of 13 Old 12-17-2012, 4:50 AM
I will try that but if i cant send a 954 map supplied by power commander to the 954 unit so thats y i thought something must be wrong with the data cable or something.my friend spent an hour and a half with me trying to do it and he runs a pc shop so no stranger to a computer and he couldnt get a map to send neither
This is a new PC rather than a secondhand one?
Can you return it for the correct one for the 929?
post #7 of 13 Old 12-17-2012, 4:55 AM Thread Starter
Yes unfortunately a second hand unit,hope to phone dynojet later
post #8 of 13 Old 12-17-2012, 4:57 AM
In that case it may not work.
PC's are not the hardiest creatures and are known to fail.
post #9 of 13 Old 12-17-2012, 5:51 AM Thread Starter
I spoke to dynojet and he thinks its down to the serial to usb cable ,he reckons if i can find an old computr with a serial port then he almost guarentees that it will work .the serial to usb cable is mega unreliable .i go hunt for a relic pc
post #10 of 13 Old 12-17-2012, 4:38 PM Thread Starter
Bladeracer this is what i get when i plug my power commander to the pc.what do i do
20121217_202459.jpg‎
post #11 of 13 Old 12-18-2012, 12:04 AM
Are you using the serial or USB version of the software?
post #12 of 13 Old 12-18-2012, 10:52 AM
Reputation Power: 113
The clue's at the bottom of the screenshot. Wrong software version.
Sky91 is offline
post #13 of 13 Old 12-18-2012, 11:09 AM
As my experience b4, PCIIIr can not use USB connect to your PC , you should use this kinda pc wire to connect your old model desk computer.
AND I will recomment that you should going to get PCIII usb model for your loptop, much easier and better...
Hung is offline
CBR 929RR-954RR Power Commander PCIII USB, Power Commander Ignition module, Hub, , Cl like2ryde For Sale 32 05-04-2012 1:17 AM
Power Commander III TeeJay Honda FireBlade 4 04-11-2011 8:59 PM
looking for a 954 power commander boricp Honda FireBlade 6 03-10-2008 2:37 PM
Power Commander mike turner Honda FireBlade 12 02-20-2008 9:21 AM
