Indicator delay - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 12-19-2012, 3:47 AM Thread Starter
Quoted: 3 Post(s)
Reputation Power: 11
Indicator delay
Hi
when I start the bike from cold, and flick an indicator, it takes about 5 seconds for it to start flashing, same with the other side, however, after the initial delay, when I cancel the indication, then indicate the SAME side it starts flashing instantly. After its warmed up, the delay is about 2 seconds.
All indicator lights are working with the right wattage bulbs (23w) and it has a new battery.
Could this be a faulty relay or something other?
Hawkes is offline
post #2 of 5 Old 12-19-2012, 8:22 AM
Reputation Power: 113
Re: Indicator delay
Clean your switch out and check for corrosion.
Sky91 is offline
post #3 of 5 Old 12-20-2012, 4:09 AM
Reputation Power: 28
Re: Indicator delay
What he said ^
Surteez is offline
post #4 of 5 Old 12-20-2012, 8:05 AM
Reputation Power: 34
Re: Indicator delay
First blast the indicator switch with wd40. If that doesn't help replace the relay, get one of the LED ones off eBay, direct swap, and since they're all electronic should last longer, including if you later fancy LED indicators.
amorti is offline
post #5 of 5 Old 12-20-2012, 12:59 PM Thread Starter
Quoted: 3 Post(s)
Re: Indicator delay
Thanks for your suggestions.
I fired a shed load of wd40 in to the switch and clicked like mad, now its pretty much instant, not perfect but good enough for now, until I can get around to stripping it at a later date.
Cheers and merry christmas!
Hawkes is offline
01 F4I delay/hesitation at low RPM's Cooterboy87 Honda CBR 600 19 04-18-2013 6:01 PM
Indicator delay SpankyBlade Electronics 3 08-11-2011 9:45 PM
throttle delay dr_love Honda FireBlade 7 05-23-2007 12:20 PM
Don't Delay jaim Politics 0 04-04-2006 4:04 AM
And yet no mention of DeLay here. jaim Politics 85 10-20-2005 11:20 AM
