Tools Needed for 929 Swingarm Removal and a few questions - Honda Motorcycles - FireBlades.org
post #1 of 15 Old 12-20-2012, 5:28 AM Thread Starter
Reputation Power: 11
So I found a 954 swingarm removal write up which is pretty good, but it does not list what tools are needed. My main question is do I need a giant allen key or allen socket? Where the swingarm is held on at the front most point there are giant hex holes where the pinch bolts are. Do those hex bolts need to be unscrewed or is that all one piece that gets pushed out when I loosen the pinch bolts?
EDIT: It looks like its a 24mm hex, when I try to loosen one side will the other side just spin? It seems like it would causing me to need another person with another 24mm hex tool?
I am also confused on the bearing situation on the swingarm. I bought a bike that came with an extra so I do not know if it is missing anything. One side has a metal sleeve that slides right out in one piece exposing the roller rod bearings. The other side has a cap I guess you can call it that comes off but the metal sleeve does not push out by hand. I am guessing it needs to be pushed out by a machine. I can see all the grim underneath the sleeve so I would like to clean and regrease my bearings, but I am not sure if it is normal to only have one cap on the other side of the swingarm? Also the side with the cap does not spin freely like the other side does. I should have taken pictures because that probably doesnt make sense.
Any help is appreciated, I want to swap swingarms this week in my garage.
01 929
socci is offline
post #2 of 15 Old 12-20-2012, 6:04 AM
Re: Tools Needed for 929 Swingarm Removal and a few questions
Just make the tool for the swingarm hex using a nut welded to a bolt of the correct size.
Either the Haynes or OEM manuals should have all the info you need.
The fiche have exploded diagrams of all the pieces so you can account for everything.
Swingarm (1) Honda CBR929RR 2001 OEM Parts - Cheap Cycle Parts
post #3 of 15 Old 12-20-2012, 2:22 PM Thread Starter
Yea the service manual I have now doesn't mention the tools or get into as much detail as I would like, might be time to buy a Haynes.
01 929
socci is offline
post #4 of 15 Old 12-20-2012, 3:14 PM
Reputation Power: 10
x2 for the nut welded on a bolt works great i believe the bolt head must fit a 24mm socket.
cutsheal5 is offline
post #5 of 15 Old 12-20-2012, 7:44 PM Thread Starter
I don't have any way to weld it though.
01 929
socci is offline
post #6 of 15 Old 12-20-2012, 8:37 PM
Then take it to somebody that can?
post #7 of 15 Old 12-20-2012, 9:10 PM Thread Starter
What are the chances JB Weld can hold for that type of job?
01 929
socci is offline
post #8 of 15 Old 12-20-2012, 9:16 PM
Nil.
Get it welded.
It takes all of ten seconds to hit it with an arc welder.
post #9 of 15 Old 03-24-2013, 1:18 AM
Reputation Power: 9
or u can just use more then one nut!
dons929 is offline
post #10 of 15 Old 03-24-2013, 1:21 AM
Reputation Power: 9
fill bolt with nuts then take hammer bet the hell out of the end of bolts (nuts will never come off again!) there u go, just wanted to add that
dons929 is offline
post #11 of 15 Old 03-24-2013, 9:42 PM
Reputation Power: 34
24mm sounds like one of those multi sized front wheel keys to me.
amorti is offline
post #12 of 15 Old 03-25-2013, 3:46 AM Thread Starter
Yea I ended up using a buddy's welder and welded two nuts onto a 24mm bolt. Worked great.
01 929
socci is offline
post #13 of 15 Old 03-25-2013, 6:48 AM
Reputation Power: 9
BTW how did you end up holding the bike up so you could remove swingarm?? Getting ready to put a chrome one on mine.
dons929 is offline
post #14 of 15 Old 03-25-2013, 2:24 PM Thread Starter
I hung it from the ceiling. The unfinished part of my basement had trusses or whatever they are called and I used some heavy duty ratcheting straps. I found the swingarm removal to be really easy for me the worst part was putting the rear wheel back on.
01 929
socci is offline
post #15 of 15 Old 03-26-2013, 12:29 AM
thats what i use whenever i pull my swingarm off. has the 17,19, 22, and 24mm i believe
Jdub336 is offline
Any special tools needed to replace fork seals HeadlessHrseman Honda FireBlade 11 02-01-2012 8:14 PM
93 CBR 900RR castle nut removal tools TandJ Tools / Garage / Paddock 2 06-06-2011 2:16 PM
CBR 954 extended swingarm or swingarm extentions needed asap santanaea5785 Wanted 1 04-19-2009 8:30 PM
Questions about a tool needed to get an 02' Swingarm off reelop19 Honda RC51 2 06-02-2008 2:55 PM
Special Tools needed for fork work? mharrison Honda RC51 0 04-07-2008 4:56 PM
