K&N - worth it? - Honda Motorcycles - FireBlades.org
post #1 of 17 Old 12-23-2012, 1:08 PM Thread Starter
Reputation Power: 34
K&N - worth it?
My RRW has a K&N on, plus stock header and quite tightly baffled Leo Vince slip on. In principle I like the idea of a washable, re-usable air filter, but what I really want is a bike that runs as smoothly, and economically as possible. I don't feel like mine is quite right at lower revs (below 4k) which is where I'm stuck at on my urban commute. Could be as simple as cleaning and checking carbs over (I took a swift look, one was immaculate so left the rest alone as it was getting dark) and a rebalance, but will it ever be as nice on the K&N as it would be stock, without pissing about rejetting?
On my quick check the jets were original, 124 mains and I forget the pilot size. I don't need the hassle of rejetting and IDGAS about getting the last half horsepower out of it, or to be honest even if it gave 5 at the expense or low range manners I wouldn't want it. Will fitting a stock filter make it run nicer?
amorti is offline
post #2 of 17 Old 12-23-2012, 1:42 PM
Re: K&N - worth it?
I would stick with OEM filters, but I would also use a lower gear to get your revs up.
post #3 of 17 Old 12-23-2012, 5:49 PM
Reputation Power: 55
Re: K&N - worth it?
simple answer: no
52brandon is offline
post #4 of 17 Old 12-23-2012, 6:03 PM
Re: K&N - worth it?
I use a BMC but that is just because i got it cheaper than oem, the price you pay for a k&n or bmc is not worth it in my opinion. Like blade racer said that money is worth more on the drive train(ie sprockets and chain).
CMFM22 is offline
post #5 of 17 Old 12-23-2012, 9:29 PM
Re: K&N - worth it?
Actually, I was just advising him to stop trying to ride the bike under 4000rpm, that's what they make cruisers for, not sportsbikes ;-)
post #6 of 17 Old 12-23-2012, 11:31 PM
Reputation Power: 59
Re: K&N - worth it?
That is the biggest thing.. If you feel the bike lugging, then you ride in a lower gear. I dont see an air filter making a big difference there.
James Taylor
Krazed is offline
post #7 of 17 Old 12-24-2012, 8:38 AM Thread Starter
Re: K&N - worth it?
Turn out 124 means its already been jetted up forthe filter and pipe. I thought it was stock but stock was 120. Could even be the baffle in the pipe is too tight causing it to run rich.
I'll give the carbs a strip and clean up "soon" and see what I find. Could be the idle screws are way out, If it's also been fitted with adjustable needles could be they're set wrong.
It's at its worst in town in first and second about 3-5k. Don't have much room to shift down as there's a lot of 30km/h zones.
If I can't get it working right easily therell be a k&n and 124 jets for sale or p/x on stock parts. Post to from Spain though. Don't hassle me by pm just yet, if it gets there I'll update here and post in for sale.
amorti is offline
post #8 of 17 Old 12-28-2012, 11:27 AM
Reputation Power: 10
Re: K&N - worth it?
I bought a bike used last year and it had a k&n filter installed . I didnt know abiout it. The seller never told me. He said everything was stock except for the pipe. When i went to do a little maintenance on the bike I ordered a new filter just incase. Figured I would have it in the future if i needed it. When i took the airbox off and saw the k&n was dirty i put the oem filter on while i cleaned the k&n. Noticed a difference. After cleaning the k&n and reinstalling it i noticed a huge difference in throttle response, not power .
cc rider is offline
post #9 of 17 Old 12-28-2012, 11:43 AM
Re: K&N - worth it?
I do not trust the oiled gauze (or foam) filters to keep the dirt & dust out. They just don't filter as well, and there is no power advantage on the street.
The ONLY time I would even consider using one is on a dedicated track or race bike, and even then I'd be hesitant.
TexasTraffic is offline
post #10 of 17 Old 12-28-2012, 12:19 PM
Re: K&N - worth it?
I don't know. They've been around a while so they must be doing something right. When you oil , it shouldn't be a wet oiling to where it attracts dirt. I just loved the difference it made in throttle response. I've never heard of engine damage cause of them.
cc rider is offline
post #11 of 17 Old 12-28-2012, 1:23 PM
Re: K&N - worth it?
Yes, their marketing is great.
The kind of damage from less-than-great air filtering would not be outright engine failure. It would be increased wear & possible scoring on cylinder walls & rings, and also increased bearing wear. You'd have to do an engine tear-down and inspection to find it. An oil analysis would give some clues with elevated Silicon readings (dirt), and elevated wear materials after some damage has occurred.
These are things you must actively look for to notice vs. something like the engine throwing a rod through the case.
post #12 of 17 Old 12-29-2012, 7:22 AM
Reputation Power: 12
Re: K&N - worth it?
K&N = low maintenance almost fool proof filtering, not the best filtering.
Will it cause damage to the engine? Probably not, but they have been known to disagree with some MAP sensors.
Will you be getting the maximum air flow? Simply put, No.
Stick is offline
post #13 of 17 Old 12-29-2012, 7:32 AM
Re: K&N - worth it?
They're great for US car engines designed in the 60's, their bike and modern car stuff is simply following on that reputation, without actually offering any improvements over the much more highly developed OEM filtering systems used on these engines. Stick with OEM.
post #14 of 17 Old 12-29-2012, 11:41 AM
Re: K&N - worth it?
Wow. Some K&N haters here. So, maybe the better throttle response is from "less filtering"?
cc rider is offline
post #15 of 17 Old 12-29-2012, 11:45 AM
Re: K&N - worth it?
"Better throttle response" is a subjective statement that is difficult to measure or prove simply by riding the bike.
Lots of people think their bikes are faster when they put a muffler on, but really they just sound faster :-)
What's she worth? MidwesterneRR For Sale 20 04-24-2012 12:48 PM
89 cbr 600 is it worth it?!?!?!?! m4punk General Discussion 8 04-18-2010 1:38 PM
Is it really worth it??????????????? 954maniac Honda FireBlade 7 01-25-2009 5:56 PM
What is a 03 954 worth chrisbratton22 Honda FireBlade 19 04-18-2006 5:04 PM
Is it worth it l'timbré Honda FireBlade 89 01-26-2005 9:12 PM
