2006 CBR1000 won't start - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 01-02-2013, 1:26 PM Thread Starter
Okay so this isn't the typical won't start questions. I picked up a project from a friend of mine and it is a 2001 Honda CBR600 frame with a 2006 CBR1000 engine in it. The bike is horrible and I would never ride the thing but I need to see if the motor will run (I was told it was running).
Bike has 06 CBR1000 engine, wiring harness, ecu, throttle bodies, etc. The problem is there are no connections made, the harness is plugged into the ecu and injectors etc but no external connections are made being that there either arent places for them or they are cbr600 connections.
What I need to know is what has to be plugged up for it to run? I'm assuming I cant jump it off of the starter like a carbureted motor because you wouldnt get any fuel but when I do jump the starter I'm not getting any spark to the plugs either.
I'm a kawi guy and I know kawisaki has a shutoff in the cdi that if the key isnt engaged the plugs won't fire, am I looking at something similar?
Let me know if there is any other details I can give. Thanks
Tswami is offline
post #2 of 6 Old 01-02-2013, 1:59 PM
Re: 2006 CBR1000 won't start
You will need the bank angle sensor mounted correctly to get spark.
When you confirm you have spark, hook a battery up to the starter motor and spray starter fluid into the throttle bodies while cranking the engine over. It'll run all day on starter fluid.
Assuming it's a US ECU then there shouldn't be an immobiliser to worry about.
Ideally you will want a 1000RR instrument cluster to confirm all the sensors in the injection system are operating properly. Without it you will have to manually test each sensor if you don't have spark.
post #3 of 6 Old 01-02-2013, 3:11 PM Thread Starter
Thanks,
I am familiar with a bank angle sensor just curious where it would be in the harness and its orientation for this motor?
Also would the kickstand sensor keep it from firing as well? There is no kickstand at the moment. I could bypass it but I dont want to do that unless I have to.
I jumped the motor off by the starter since the ignition isnt hooked up (which may also be one of my problems) with starter fluid. As long as I can get it to fire up I'll be happy.
Thanks again.
Tswami is offline
post #4 of 6 Old 01-02-2013, 3:14 PM
Thanks,
Thanks again.
BAS is mounted on the headlight.
Not sure about the sidestand, that generally breaks the starter motor circuit except when the clutch is pulled in. Don't know if it cuts ignition as well.
post #5 of 6 Old 01-21-2013, 4:00 PM
If its in neutral you can start it whether the kickstand is up or down. You need to have the upper harness plugged in so the bas is connected to get spark. Kill switch needs to be on run as well. Cam sensor has tone plugged in too.
Badnblack is offline
post #6 of 6 Old 01-23-2013, 10:00 PM
HONDA.PNG‎   HONDAII.PNG‎   HONDAIII.PNG‎
robbskittles is offline
2006 CBR1000 Manual LetMeIn General Discussion 5 02-17-2013 6:07 PM
Will a 2006 CBR1000 engine fit into a CBR954? frank Honda FireBlade 15 12-31-2012 2:32 AM
New 2006 cbr1000 brokinfith Honda FireBlade 0 12-05-2012 5:46 AM
First Ride - New 2006 CBR1000 R-Law Honda FireBlade 4 05-18-2007 11:05 PM
2006 cbr1000 hp? bgprbrad Honda FireBlade 7 08-20-2006 6:05 PM
