rad fan problem 900rr 1997 - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 01-09-2013, 12:26 AM Thread Starter
Hi Guys!
My rad fan won't start...
What I've looked so far :
-thermostat works
-when I make a short, the fan starts
-fuse is ok
Firefrank is offline
post #2 of 7 Old 01-09-2013, 12:35 AM
Re: rad fan problem 900rr 1997
Sounds like the fan switch has failed, also known as the thermostat switch(The bit that screws into the rad).
David Silver Spares - Parts For Honda Motorcycles - Honda CBR900RRV FIREBLADE 1997 Thermostat switch
stevecbr1000 is offline
post #3 of 7 Old 01-09-2013, 12:49 AM
Originally Posted by Firefrank View Post
Hi Guys!
-thermostat works
-fuse is ok
You do know that it's not supposed to run until the engine exceeds boiling point?
post #4 of 7 Old 01-09-2013, 12:59 AM Thread Starter
yes, the temps goes up on my gauge and the fan never goes on.
post #5 of 7 Old 01-09-2013, 1:01 AM
It goes above 102C?
In that case you need to check the thermo switch and its wiring.
post #6 of 7 Old 01-09-2013, 9:51 PM
Reputation Power: 34
What 'racer said.
On my 98 (digi temp gauge) it gets to 104c before the fan cuts in - I was getting worried as even in December daytime temps are around 20-23c and I spend plenty of time in a border Q. I seriously doubt your fan will even be activating in normal use in Canada at this time of year.
amorti is offline
post #7 of 7 Old 01-10-2013, 4:05 AM
Why not just jump the fan to see if it works? (hook up a ground and a 12volt power source and see if it fires up)
GL!
MattCBR is offline
1998-99 CBR 900RR face to 1996-1997 CBR 900RR mech5398 Honda FireBlade 26 02-04-2013 5:47 AM
1999 cbr 900rr Ohlins Rear shock to fit 1997 cbr 900rr? BladeNewbie Aftermarket Perfomance Parts Reviews 0 09-20-2011 6:53 PM
NJ: 1997 900rr gillette Motorcycles For Sale 4 06-28-2011 8:45 PM
Hello, 1997 cbr 900rr jweezee911 Introductions 4 03-15-2009 6:47 PM
1997 900RR maintenance Choppa Honda FireBlade 4 12-05-2006 9:12 PM
