1994 CBR900RR radiator issues - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 01-13-2013, 10:59 PM Thread Starter
My CBR h is spewing coolant from the radiator cap at idle as soon as it gets to operating temp. I replaced the cap thinking it was the issue but still dumping coolant out the cap. I got to looking and it seems the lip on the radiator filler neck is bent down so I straightened it the best i could and put a rubber stopper in under the cap to totally block of the cap and put the cap over it. Still blew out coolant. So i ran a compression test thinking blown head gasket but all cylinders read great compression. My question is simply by me blocking off the reservoir and cap but putting in the stopper would it create enough pressure to blow by the stopper and out the cap or is there excessive pressure coming from somewhere else? If it is normal pressure that means i have to junk a perfectly great radiator over a stupid bent lip or is there any other fix you guys can help me think of.
If you want sympathy look in the dictionary between s**t and syphilis that's were it can be found.
thunderpipes127 is offline
post #2 of 7 Old 01-13-2013, 11:28 PM
Re: 1994 CBR900RR radiator issues
Is it running hot or does it do this even when cold?
post #3 of 7 Old 01-14-2013, 12:36 AM Thread Starter
It only does it after it get to the half way mark on the temp gauge or a hair above it. I can take the stopper and cap off, top it off with coolant and sniff it for exhaust fumes with my test kit I get nothing and the coolant stays put until the bike warms up then it starts to push it out and steam. I can't think of a way to seal it off so it will stop gushing coolant. It doesn't run hot until it had sat and ran for about 20 minutes but by that time I'm sure it has leaked all the coolant out is why it starts to run hot. The fan kicks in at the 3/4 mark like it should so at least that's working. Water pump is pumping great but the cap will not keep the coolant in. I need a way to repair rather than replace if possible. I have everything you can think of at my shop to make repairs just can't think of a way to do it. I can tighten the cap and see the gap under it because of the bent lip but i figured the stopper which fits in super tight would be enough force to keep the coolant from pushing out unless all i am doing is makeing the system over pressurize because the pressure has no reservoir to release into. Or should it not have that much pressure I'm not sure. It only has 15000 miles on it but the previous owner dumped it out of his truck when he was loading it up to bring it to me I gave $500 for it and it came with a box of brand new never installed complete body work. He told me it had a bad ignition switch and starter which both turned out to be a blown main fuse so this guy was an idiot of that I have no doubt.
post #4 of 7 Old 01-14-2013, 10:24 AM
Reputation Power: 15
Sounds like you have a bad filler neck, specifically the part you bent back.
You may have to replace the radiator or perhaps replace the neck if you can find the part and a radiator shop that will do it.
rudyrov is offline
post #5 of 7 Old 01-14-2013, 3:08 PM Thread Starter
I will try to find a compatible neck and I can weld it myself. I wonder if a honda car would have around the same diameter neck. If not I will go to a local bike boneyard and try to pick one up. If that fails I will eBay another complete unit.
post #6 of 7 Old 01-15-2013, 9:28 AM
You might be able to do a reverse look up by seeing what vehicles fit that same radiator cap. Worth a try anyway.
rudyrov is offline
post #7 of 7 Old 01-15-2013, 11:28 AM
Quoted: 2 Post(s)
Are you sure its over flowing because its not circulating properly? most car/bike radiators flow in one direction through one end of the engine out the other and through the radiator. often goes from left to right of the bike with the radiator cap being on the right side... have you checked to see if there is anything clogging the system causing it to over pressurize and leak at the cap? might be time for a system flush before you think about replacing the radiator.
a good way to spot clogging in coolant system is get the bike up to temperature and then feel the radiator hoses... if one is hot and one is cold... chances are you got our self a clog or a bad or maybe over worked water pump
nyknick1015 is offline
1994 cbr600 f2 stalling issues Bartman352004 Honda CBR 600 14 03-30-2015 2:59 AM
1994 cbr600 f2 stalling issues sk_auto_63033 Honda CBR 600 3 02-16-2011 12:49 PM
1994 cbr900rr where to put oil veryverynew General Discussion 6 12-06-2010 10:37 PM
1994 RR-R Fireblade Gearbox issues... tubthumped Honda FireBlade 4 04-02-2009 5:33 AM
1994 CBR900RR scutfargas Review My Ride 10 02-02-2009 12:05 AM
