954 fuel gas cap tank Am I missing something? - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 01-16-2013, 7:02 PM Thread Starter
Between the outer edge of the gas cap and the tank there is a gap that is open to the air. Rain can actually go in that gap and funnel down to the drain hole into the tank. I looked to see if there was a gasket missing but it seems there is not. The cap and the bolts are all there is to it. Is it broken? Can I fix it or do I have to buy a new cap ?
bkl070 is offline
post #2 of 6 Old 01-17-2013, 12:21 AM
Quoted: 29 Post(s)
Re: 954 fuel gas cap tank Am I missing something?
I'll have a look at mine in a few minutes.
jdoni is offline
post #3 of 6 Old 01-17-2013, 12:26 AM
that hole goes through the tank and down to the tube near the kickstand. it does not let rain water into the gas tank.
LasVegasHarley is offline
post #4 of 6 Old 01-17-2013, 3:29 AM
The drain runs through the tank and vents to the ground.
post #5 of 6 Old 01-28-2013, 2:56 PM Thread Starter
Thanks. So that is not open to the fuel. Also, don't spill any fuel when you fill you tank. I went and looked and saw it in about 1 sec. I am not as dumb as I appear to be most of the time. And the fact that two of the dummy screws are missing means nothing. Good.
bkl070 is offline
post #6 of 6 Old 01-28-2013, 3:34 PM
Reputation Power: 113
Don't go filling it up right to the neck either. Best to stop an inch or two below.
Sky91 is offline
WTB 929 fuel tank stiffer56 Wanted 2 04-21-2012 6:56 AM
Need fuel tank JOdom Honda Cruisers 0 09-20-2011 1:23 AM
fuel tank natorious Honda FireBlade 0 06-05-2010 9:13 PM
Fuel Tank / Fuel pump seal ugt33 Honda RC51 0 10-24-2008 3:13 AM
929 fuel tank help E_RacK Honda FireBlade 6 05-29-2007 10:52 PM
