900 RRW Running lumpy - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 01-19-2013, 9:48 AM Thread Starter
Quoted: 2 Post(s)
Hi Guys and girls,when i first bought my blade it had been standing and the tank and carbs were full of rust i cleaned everything out i pressue washed the tank and got it near perfect and the carbs i used carb cleaner and an airline to blow everything through,but on start up its popping around on no 3 for a few seconds and when its warm the tickover is up and down from 1100-1500,I have balanced the carbs which are spot on,The bike has done 19k miles and i did not get any history with it im guessing the miles are right because when i had the tyres changed 12 years old,I just wanted advise to weather it could be the shims need looking at or its a carb problem,the bike runs fine other than that
warloks38 is offline
post #2 of 8 Old 01-19-2013, 9:52 AM
Quoted: 6 Post(s)
Reputation Power: 26
Re: 900 RRW Running lumpy
You used carb cleaner. Did you use it on all the disassembled parts? or just spray it where you could reach? I think that if you perform the full carb cleaning ritual you will find a big change for the better.
ghbzorro is offline
post #3 of 8 Old 01-19-2013, 9:56 AM
Reputation Power: 34
The gauze filters in the tank rot after a length of time. You can get a regular inline filter and just about fit it in the fuel line from the tank to the carbs. It's a bloody mystery why Honda didn't do this in the first place.
Fit one, clean your carbs once more for luck, and see where you are.
I wouldn't be surprised if there is a small amount of water in your tank either. You can add methylated spirits to dissolve it in the petrol, or tip the petrol out and skim the petrol off the top of the water.
You may also have a leaky carb boot if your tickover won't settle, or shims out of spec.
amorti is offline
post #4 of 8 Old 01-19-2013, 10:33 AM
You did strip everything out of the carbs when you cleaned them right?
post #5 of 8 Old 01-19-2013, 12:58 PM Thread Starter
Quoted: 2 Post(s)
I only stripped the carbs down as far as I could without seperating them the fuel tank is clear or any water and I have an inline filter fitted
post #6 of 8 Old 01-19-2013, 2:01 PM
But you did remove all the jets, emulsion tubes and mixture screws to clean out the pilot circuits?
post #7 of 8 Old 01-19-2013, 3:14 PM Thread Starter
Quoted: 2 Post(s)
i took out every jet that i could,also took out the throttle slides,Also did a compression test and that seemed fine,Ive heard of ultrasonic cleaning can this be the way forward,I think the shims need to be done but i will have to let my dealer do that always had suzuki gsxrs before the blade they had tappets so it was an easy job to check valves
post #8 of 8 Old 01-19-2013, 3:21 PM
Your idle is controlled by the pilot circuits which are almost microscopic so the mixture screws and pilot jets have to be removed for cleaning.
How hot is my f4 actually running? Stephenscbr Honda CBR 600 1 06-29-2012 5:02 PM
Running Hot pgafuture Honda FireBlade 4 11-07-2009 2:29 AM
running lights....not running antisleepman Honda RC51 3 03-17-2008 9:25 PM
Running Hot timgo Honda RC51 4 02-24-2006 10:46 PM
Lumpy idle JWHT Honda FireBlade 9 07-26-2004 7:49 PM
