954 Vent Tube Connection - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 01-22-2013, 5:31 PM Thread Starter
Can someone help me with a vent tube question on my 954 please?
The rubber tube from the fuel tank air vent connects to a 'T' piece behind the throttle bodies. One side of this 'T' piece has a tube that goes down to a cut out in the bottom of the left hand fairing (sits next to the fuel tank overflow tube in this cut out).
My question is where does the tube on the other side of this 'T' piece connect to, as mine has come off from somewhere and i can't see where it should go
Cheers
Simon
r15suk is offline
post #2 of 7 Old 01-22-2013, 6:54 PM
Re: 954 Vent Tube Connection
Cheers
Simon
It just splits to both sides of the bike I think.
Fuel Tank (2) Honda CBR954RR 2002 OEM Parts - Cheap Cycle Parts
post #3 of 7 Old 01-23-2013, 3:44 PM
Quoted: 2 Post(s)
Reputation Power: 15
ahhh okay... this makes sense now... I took this off from my bike last summer because it got disconnected some how but when i looked all over the tank and everything, didnt know where it connected... its not a necessity then?
nyknick1015 is offline
post #4 of 7 Old 01-23-2013, 4:51 PM
Reputation Power: 113
I don't have mine connected at all. Never had any problems.
Sky91 is offline
post #5 of 7 Old 01-23-2013, 7:07 PM Thread Starter
Ok ta. any idea where its 'supposed' to come out? The one on the left has the slot in the fairing panel.
cheers
Simon
r15suk is offline
post #6 of 7 Old 01-23-2013, 9:11 PM
It's just a safety thing so you don't have fuel or vapour leaking out over the hot engine or exhaust system.
post #7 of 7 Old 01-26-2013, 5:48 AM
Reputation Power: 9
I didn't connect mine up after my engine rebuild. Fuelled up at petrol station, paid and when I came out there was I reckon about a litre of fuel on ground and more dripping out. Quickly jumped on and took off as quick as possible. I just put one line up into the wiring harness on the left side up high just under the tank. Seems to have fixed my problem
robdanjor is offline
Rev Limit for 954 ECU - B17 - B20 connection swtos Honda FireBlade 15 04-26-2011 1:25 AM
PCIII USB connection Issue. SpikedLemon Honda FireBlade 5 10-15-2010 8:54 PM
08 Electrical connection Rhojef Honda FireBlade 2 06-28-2010 3:33 AM
Carb vent tube location? texassuperhawk Honda CBR 600 0 05-02-2008 7:45 PM
air vent tube between 1&2 carb jeffrow37341 Honda FireBlade 0 03-21-2007 7:20 PM
