929 Fuel Filter Line Size? - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 01-23-2013, 12:31 PM Thread Starter
Reputation Power: 11
Does anyone know the size of the lines that run to and from the fuel filter on a 929? I am asking because the only filter I can find cost 50 dollars, and that seems crazy to me. Walmart and other stores have universal ones that I am considering trying to rig up. I do not know if it will even work but figured I would get more input on it. If I can get a filter with the same size diameter of inlet outlet tubes I dont see why it wouldnt work.
01 929
socci is offline
post #2 of 9 Old 01-23-2013, 12:47 PM
Re: 929 Fuel Filter Line Size?
I have been thinking same thing but the filter have this U-profile income.
Here is a picture where you can see what the filter looks like:
samba2 is offline
post #3 of 9 Old 01-23-2013, 1:31 PM Thread Starter
I think it should work as long as we have a filter rated with a high enough psi and we replace the hoses with longer ones to accommodate the new shape. I saw some filters at Walmart that look just like that for 12 bucks. I might have to give it a try while my tank is off.
01 929
socci is offline
post #4 of 9 Old 01-23-2013, 1:46 PM
Sounds like good plan. If it works, put some pictures so I might do the same thing
samba2 is offline
post #5 of 9 Old 01-23-2013, 3:24 PM Thread Starter
Yea I am going to give it a shot, I just hate eyeballing tube diameter so I was hoping someone knew. I do not see it in the manual.
01 929
socci is offline
post #6 of 9 Old 01-25-2013, 9:20 PM Thread Starter
So far no luck. I took my filter off, went to walmart, autozone, and pepboys and none of them have a filter close enough in size (all too big). I am either going to try and find something online or just throw it back on and hope it doesnt clog anytime soon.
01 929
socci is offline
post #7 of 9 Old 01-26-2013, 6:18 AM
What size is that filter and have you looked in ebay?
There are lots different filters:
samba2 is offline
post #8 of 9 Old 01-26-2013, 2:47 PM Thread Starter
Yea but I think those are for non-pressurized fuel systems like bikes with carbs. I could be wrong, but I dont think they will hold up under pressure.
01 929
socci is offline
post #9 of 9 Old 01-27-2013, 4:39 AM
I'm using Walbro pump to run on OEM filter, still wondering if there's good filter to match this pump, don't know if OEM filter good enough for this strong pump.
Hung is offline
95 900rr Fuel line size??? MN900RR Honda FireBlade 0 01-04-2012 6:36 PM
fuel filter size.. Labtec104 Honda CBR400RR 2 10-08-2010 1:36 PM
Fuel Line connection to Fuel Pump kenestle Honda FireBlade 14 09-20-2010 4:49 PM
Clogged Fuel line/filter??? Gruvin2 Honda FireBlade 0 05-09-2008 12:33 PM
Fuel Line Size 2001 929rr Honda FireBlade 0 06-26-2003 9:47 PM
