CBR1000rr fuel injection on CBR929/954rr - Honda Motorcycles - FireBlades.org
post #1 of 24 Old 01-23-2013, 2:21 PM Thread Starter
Hi all
To all CBR929/954rr friends,Who has done CBR1000rr fuel injection system on CBR929/954rr model?Can anyone share some pics?
The fuel injectors' wire are same as CBR954rr that I did try to bolt on, But the secondary injectors on the top is the problem to bolt on....
Anyone of you have heavy modified your CBR929/954rr, please share some pics..
Hung is offline
post #2 of 24 Old 06-05-2013, 10:38 AM
Re: CBR1000rr fuel injection on CBR929/954rr
MMhh Also wanted to know......I have a 929 with clogged injectors, so maybe I just want to use the head injectors not the seconary ones.
Thanks and greetings,
Erik.
activate1 is offline
post #3 of 24 Old 06-05-2013, 5:25 PM
Reputation Power: 113
Much easier just to use the 954 TB's. They're a couple of mil bigger and will be a lot easier to hook up. They don't have the secondary injectors, but you don't need em.
Sky91 is offline
post #4 of 24 Old 06-05-2013, 5:41 PM
Thanks for the answer, I am going to look for the TB and injector and wiring...
Erik.
post #5 of 24 Old 06-05-2013, 5:43 PM
Im thinking of fiting a set from a 954 on my 929, as they can be had on fleebay for £100.
Can any one tell me if they have done the same? an did they get any more power at the top or bottom, more mpg, smoove ect ect..
77bladetime is offline
post #6 of 24 Old 06-05-2013, 7:08 PM
Quoted: 3 Post(s)
Reputation Power: 24
I have them on my 929 and have a set for sale! thou I'm waiting to here if one or two people want them??? activate1 being one of them
tweezy666 is offline
post #7 of 24 Old 10-28-2015, 5:16 PM
Reputation Power: 7
I've got the CBR1000 throttle bodies on my CBR929.
I had to pull my injector harness apart and wire it so that the TPS is on the left side instead of on the right side like the CBR929.
I had to file down the castings on the CBR1000 TBs to a smaller outside diameter circle so that they would fit into the rubber boots on the head.
I had to port open the head inlets to port match them to the CBR1000 throttle bodies so that there was a smooth transition. A rough transition there would probably produce worse flow than the smaller 929 TBs.
I had to cut a hole in the center of my Airbox to allow clearance to the throttle linkage.
I am now trying to tune the set up. I took it to a shop and they did a couple pulls on the dyno. They said that they have increased the fuel as much as they can and it is still lean. They recommended putting the factory TB back on. I may try increasing the fuel pressure with an AFPR or finding bigger injectors before I give up and go back to the factory TBs.
-Sly-
Slycrew is offline
post #8 of 24 Old 10-29-2015, 8:55 AM
Quoted: 33 Post(s)
What numbers did you make? Have you tried fitting 929 or 954 injectors to those tb:s? 1000RR has 8 injectors so 4 of them won't necasserily be enough.
mika_u is offline
post #9 of 24 Old 10-29-2015, 10:42 AM
Reputation Power: 7
I haven't tried the 929 or 954 injectors. Does anyone know what size they are? Are the 929 and the 954 injectors the same cc? I wonder what the 1000 injector cc is?
It would make sense that the 1000 injectors are smaller. That would explain why I can't get it to the right AF ratio.
They did 2 pulls and couldn't get it right but the number was 135 hp. They told me to fix it and bring it back.
What is a good AF ratio? I heard these bikes like 11.5:1
-Sly-
Slycrew is offline
post #10 of 24 Old 10-29-2015, 8:44 PM
Quoted: 33 Post(s)
[URL="https://www.fireblades.org/forums/honda-fireblade/112022-hole-burnt-through-piston-954-a-2.html#post1198787"[/URL]
And there are some numbers at megasquirt forum. My AFR is somewhere about 13.0-13.5:1.
mika_u is offline
post #11 of 24 Old 10-30-2015, 3:25 AM Thread Starter
Mika
Do't you think 13.0-13.5 is kinda risk? I set to 12.8...I will post some pic with Titanium connection rods and 08+ CBR throttle boddies install my on CBR 980
Hung is offline
post #12 of 24 Old 10-30-2015, 6:12 PM
Reputation Power: 7
I found the answer to the fuel injector size question.
CBR929 = 280cc
CBR954 = 290cc
CBR1000 = 250cc (lower injectors only
-Sly-
Slycrew is offline
post #13 of 24 Old 10-31-2015, 7:23 AM
Quoted: 33 Post(s)
CBR929 = 280cc
CBR954 = 290cc
So get 954 injectors and an adjustable regulator and raise the fuel pressure to 4 bars. That should be enough.
Hung: I checked my dyno sheet. The AFR is 13.3-13.4 all the way. And it's been tuned by a guy who tunes allso most of land speed and turbo bikes here and builds motors allso. He really knows what he is doing.
mika_u is offline
post #14 of 24 Old 11-06-2015, 6:28 PM
Reputation Power: 7
mika,
which AFPR did you use? where did you mount it? could you post a picture of your AFPR setup?
factory fuel pressure is 50 psi. 4 bars is 58 psi. If the factory 954 injectors are rated at 290 cc (I'm assuming at 50 psi) then they would be about 310 cc at 58 psi. That should be perfect.
-Sly-
Slycrew is offline
post #15 of 24 Old 11-07-2015, 6:25 AM
Quoted: 33 Post(s)
I used this one. It's some chinese cheap FPR but i bought it from a local shop. I mounted it to where the HTEV servo is normally. I have a selfmade servo eliminator. But you have to change fuel line inlets to 6mm on the FPR or to 8mm on the pump which isn't so easy because the return line isn't changeable. Or buy quick releasings whit other end 6mm and other end 8 mm. I don't have a pic of it and i have stock FPR at the moment. I had trouble with the bike flooding when i took it over the stock limiter but the fault was on the pc3 ignition module. How did you mount the 1000RR tb:s and what stacks/airbox are you using? And do you have a full exhaust and what is your cam timing?
mika_u is offline
918 Fuel injection thewelder Honda FireBlade 5 04-10-2012 6:29 PM
CBR 9XX Fuel injection??? Smokngun Honda FireBlade 2 03-23-2008 8:01 AM
fuel injection daman23 General Discussion 2 12-27-2007 9:10 AM
Fuel injection unit Mdala Honda FireBlade 0 01-30-2007 11:32 PM
Fuel Injection map for '03 954 FuTAnT Honda FireBlade 12 01-22-2004 9:34 AM
