929 gearbox problems - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 01-24-2013, 3:43 PM Thread Starter
Hi guys, can any one shed any light please. i have a 929 that jumps out of 1st at hi revs and sometimes pull its self into 2nd. i have been told 1st gear is nackered, is thus true? does annone know how to fix? and does anyone have a gear box or gears? cheers
marcoblade is offline
post #2 of 6 Old 01-24-2013, 10:14 PM
Reputation Power: 23
Re: 929 gearbox problems
Nonsense! you simply are either mis-shifting (not lifting the shift hard enough in gear) or one of your shift forks is worn or bent... this is a common problem on 929/954s
Here's the how to I wrote on how to assess your shift forks, replace them, inspect the transmission, and install the fix: a Factory pro shift kit... solves the problem.
GL!
https://www.fireblades.org/forums/art...ssessment.html
MattCBR is offline
post #3 of 6 Old 02-01-2013, 11:17 AM Thread Starter
took the bike out the other day and its really bad jumping out of 1st ,2nd and 3rd. jumping from 1st - 2nd. ordered a complete gear box. do i have to completely take the engine to bits?
post #4 of 6 Old 02-01-2013, 12:38 PM
Unfortunately it's a complete engine strip job. Sounds like the dogs have gone and once it starts slipping out of gear it ruins the selector forks on that gear too.
Lots of pics of my stripdown here:
Fireblade Gearbox Photos by ganzeegeezer | Photobucket
Sorry no write up but if you need advice just shout up.
GG
ganzeegeezer is offline
post #5 of 6 Old 02-02-2013, 3:00 AM
Did you see my post?
You should really have opened her up before ordering parts... could have been just the shift fork, etc.
MattCBR is offline
post #6 of 6 Old 02-02-2013, 4:06 AM
It does seem odd that 1st, 2nd and 3rd are all jumping out of gear, if you follow what Matt's saying then this indicates that all 3 shift forks are bent. A Factory Pro kit won't fix anything, this simply gives a more positive detent for the selector drum
Providing your happy that it isn't your gearchange technique or a linkage problem that's causing the problems then you need to do some stripping.
It's easy enough to pop the sump and clutch casing off to have the shift forks out but if they seem straight and there's any damage like this
then you need to do an engine strip (even just taking the sump off and finding some bits of swarf as in my pics would indicate that you need to do an engine strip) .
The fork damage indicates dog wear, the worn dogs ride over the adjacent engaging gear and puts force on the selector fork causing the damage. If you find wear as above then all you can do is strip the engine.
GG
Tags
929 , gearbox , jumps
gearbox problems on a '97 cbr900rr Jay-blade Honda FireBlade 5 12-19-2010 11:54 AM
gearbox problems plasticmaggot Honda RC51 1 09-13-2009 6:41 PM
929/954 gearbox bannrikae Honda FireBlade 6 08-16-2009 2:21 PM
Gearbox problems on my rrv andyndy General Discussion 0 06-09-2007 3:26 PM
Gearbox problems CALLY Honda FireBlade 2 04-17-2006 3:39 PM
