CBR 954 RR No Spark, No Fuel. Help! - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 03-15-2013, 6:23 PM Thread Starter
I went out for a ride last night to try and see the comet, and when I tried to come back I couldn't get her to start and wound up riding back with the bike in the back of a pick up.
I have no fuel pump priming, and no spark.
I checked the fuel pump relay, and the pump itself, both are good. I get 0.9V pulses from the ECU at the fuel pump relay, but not enough to trip the relay.
I pulled a plug and did a spark test, nada. I even tried some of the extra spark coils and plugs I keep around.
I think the ECU isn't getting a good ground connection, how do it test this? Anyone have any other ideas?
I just don't know what the hell happened.
Jarvisx51 is offline
post #2 of 7 Old 03-15-2013, 8:27 PM
Quoted: 11 Post(s)
Reputation Power: 57
Re: CBR 954 RR No Spark, No Fuel. Help!
Check the kill switch for a loose or broken connection inside the switch. Its best to always turn off the bike with the key instead of using the kill switch.
SOLD: 03 CBR954
backdoc is offline
post #3 of 7 Old 03-15-2013, 8:58 PM
Is the bank angle sensor connected?
post #4 of 7 Old 03-15-2013, 10:03 PM
Rule out the bank angle def. jump the wires with a paper clip and try to start.
Audeliz is offline
post #5 of 7 Old 03-16-2013, 1:45 AM Thread Starter
Not the bank/tilt sensor
not the engine start relay
not the kill switch
not the fuel pump relay
Fuel pump works on the bench and when fuel relay is bypassed
fuses are all good
ECU contacts are good
all wires in the harness appear good, no obvious breaks, splits, rips or missing insulation
Engine turns over strong. head lights, fuel pump, instruments, and indicators all work.
Tried another test, I pulled the ECU and it didn't change a thing. it's almost like my ECU just up and died or has a loose connection internally. Is there a definitive way to tell with only a multi-meter and the ECU itself?
I'm starting to run out of ideas, and I bet if I had a different ecu to check it with, I could check this more easily.
post #6 of 7 Old 07-12-2013, 9:29 PM
Did you fix this
wheelieJ is offline
post #7 of 7 Old 08-21-2013, 9:01 PM
Im having the same problem with my 954
what did u do to fix the problem?
JohnnyHopkins is offline
'00 929RR no spark, no fuel th3cavalry Honda FireBlade 1 02-25-2013 2:50 PM
01 cbr 929 no fuel no spark and no luck help please cbrsquid929 Honda FireBlade 48 07-14-2012 12:44 PM
Cbr 929 no spark, no fuel pump, fredqc Honda FireBlade 0 06-09-2011 9:40 PM
929rr - Fuel, but no spark. srobinson Honda FireBlade 17 06-02-2011 10:31 AM
01 cbr 929 no spark no fuel t.hudson Introductions 7 12-05-2009 12:03 PM
