Need help,carb backfiring on 98 cbr 919rr - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 03-16-2013, 11:04 PM Thread Starter
So i just got done rejetting my 98 cbr919rr,and hooked it all back up and was about to use the motion pro carb synchronizer,I had the fuel line hooked up to a fuel funnel and had the motion pro set up,started the bike and let her run,she started to run pretty high into 3500-4000 rpms and the settled down to 1300 rpms,and she sounded all right just a little out of sync but before i could start the sync process she started to backfire from the #3 carb,I shut her down and let her settle while i tried to figure out why,couldnt figure anything out so i restarted her and she did the same thing,high rpm then right back to low 1000s rpms,then she backfired once again from the #3 carb,i could really use some advice on this one,kinda stumped on why shes doing it since she does it periodically while idling instead of continuously backfiring.
twiztedtatz77 is offline
post #2 of 7 Old 03-17-2013, 10:36 AM
Reputation Power: 34
Re: Need help,carb backfiring on 98 cbr 919rr
Are you doing this with the airbox off? Don't.
Please go make a welcome thread with pics of your bike / wife / dog
amorti is offline
post #3 of 7 Old 03-17-2013, 11:32 AM Thread Starter
yes i took the airbox off.Is there a reason why its bad to do so when your syncing the carbs
post #4 of 7 Old 03-17-2013, 12:58 PM
The carbs rely on getting the right amount of air to the fuel which is pre-metered by the jets. With the airbox off they won't get that. No CV carbs will run right without an airbox or rejetting.
Put it back on and try again.
If you don't know this, are you confident to balance the carbs?
amorti is offline
post #5 of 7 Old 03-17-2013, 2:54 PM Thread Starter
yes i'm confident enough,I'll try it with the airbox off and let you know
post #6 of 7 Old 03-17-2013, 3:50 PM
Try with it back on and let us know
PS, not joking about the intro thread and pics, it's only good form to introduce yourself
amorti is offline
post #7 of 7 Old 03-18-2013, 5:20 AM
At least put the airbox back on and see if that fixes the problem?
Tags
900 , 919 , backfiring , carb , jetting
cbr 919rr fork swap ? elwong Honda FireBlade 0 02-18-2013 9:55 PM
WTB: 1998-1999 900RR (919RR) parts alansupra94 For Sale 7 03-17-2012 10:31 AM
1998 CBR Fireblade 919RR parting out gdesmond76 For Sale 35 03-13-2012 1:31 AM
honda cbr 919rr engine trouble ryanstevens_25 Honda FireBlade 1 07-20-2008 8:59 AM
919rr high rev misfire muppetracer Drag Racing 4 05-20-2008 6:14 PM
