CBR900RR 1999 - Electrical problems? Help! - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 03-17-2013, 4:49 AM Thread Starter
Hi everybody, long time lurker first time poster.
My CBR900RR 1999 lost power on takeoff the other night all of a sudden and refused to start in the city. Called up the roadside service and was told that it had a flat battery (which I knew), but I had only replaced the battery 6 weeks prior. The multi meter test showed that the alternator was only giving out 10.7v and should have been giving out 13v apparently. I had the same symptoms with another bike of mine and it was the rectifier causing the trouble.
Does anybody have an idea as to what the problem may be? I have been googling like crazy and found pages saying that it could be the rectifier or the stator but I have no clue :/
enthusiast is offline
post #2 of 5 Old 03-17-2013, 5:19 AM
Re: CBR900RR 1999 - Electrical problems? Help!
How much mileage does six weeks equate to?
The 10.7V you measured is not from the alternator, that is merely what is left in the flat battery. The charging system is not putting out any voltage at all.
Measure the AC voltage coming out of the three stator phases, they should be something 50-70VAC on each.
It's very uncommon for rectifiers to fail in my experience, it's generally either the stator or the regulator. The stator generates the voltage, the rectifier switches it from AC to DC, the regulator regulates how much voltage is sent to the battery and dumps the excess as heat.
post #3 of 5 Old 03-17-2013, 5:24 AM Thread Starter
I would estimate that I clocked up approx 200km/week for the 6 weeks, used daily.
I'll make sure to take the aforementioned readings asap and report back.
Thanks.
post #4 of 5 Old 03-17-2013, 5:26 AM
Thanks.
If you did 1200kms then the stator clearly still had something left in it, doesn't sound like it does now though. Be sure to check the stator connector for melting or burning as well.
post #5 of 5 Old 03-17-2013, 10:28 AM
Reputation Power: 34
200km
That would be possible on a new fully charged battery if the lights weren't used, but I doubt you'd get 10 starts (a week's worth of daily use?) out of one charge on the battery. Dunno, maybe it's possible if the bike is in good tune and the battery new and fresh??
Anyway, you now probably need another new battery. At least go charge the one you have full. Then test again the charging circuit. Probably a melted regulator as that's typical for older blades, could also be any of the connectors and or the stator. Standard stuff, you need to search the site this comes up too often to give detailed answers every time.
amorti is offline
Electrical nightmares, and assorted other problems - 1995 CBR900RR Keyhole Honda FireBlade 22 03-23-2015 10:59 AM
My 1999 CBR900rr Lurch. Review My Ride 13 02-20-2011 8:23 AM
1999 CBR900rr Mikey1981 Honda FireBlade 1 03-15-2010 11:42 PM
electrical problems. cbr 900rr 1999 ZimSlim Honda FireBlade 0 05-14-2009 2:37 PM
1999 CBR900RR __DoPe_ShOw__ Review My Ride 6 02-02-2009 12:43 AM
