929 Cracked Crank Case Help - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 03-29-2013, 9:29 AM Thread Starter
Send a message via Skype™ to Matt5067
Bought a 2000 CBR929RR a few days ago. On the ride home, I hit some gravel and dropped it on its left side. The cover got cracked, so after I towed it home I started to look at it further, only to discover the main engine case is cracked, with one piece broken off. I hear this is common with 929s, but it sure bums me out. One of my friends who's a mechanic looked at it and said that if we take our time and do a good job, some JB weld should fix it. Was wondering what you guys think, and what those of you who have dealt with this before have done.
EDIT: Sorry for all the posts, would only let me upload one pic per post
image.jpg‎
Matt5067 is offline
post #2 of 7 Old 03-29-2013, 9:30 AM Thread Starter
Re: 929 Cracked Crank Case Help
Pic 2
image.jpg‎
Matt5067 is offline
post #3 of 7 Old 03-29-2013, 9:32 AM Thread Starter
Pic 3
image.jpg‎
Matt5067 is offline
post #4 of 7 Old 03-29-2013, 11:33 AM
If you burn all the oil out of the metal JBWeld _might_ work, but it'd be a better fix to get it properly welded.
post #5 of 7 Old 03-29-2013, 10:36 PM
Reputation Power: 78
Agreed.
Have someone tig it.
Then use a flat file to create the flat sealing surface you need.
Wipe all shavings out before assembling.
BurtonF166 is offline
post #6 of 7 Old 03-30-2013, 1:53 PM Thread Starter
Thanks guys, I contacted a welding shop, looks like I'll be bringing it in next week. Might as well have it done right.
One more question; one of the pieces that got cracked has the lower locating pin hole for the stator. One guy who looked at it was pretty worried about getting it lined back up perfectly. How important is it to get the coils inside the stator cover centered inside the flywheel? As long as its not touching would it be fine?
Matt5067 is offline
post #7 of 7 Old 03-30-2013, 8:17 PM
I would install the stator cover with the broken piece in place, tack the piece in place and then remove the cover to complete the weld.
how to repair the 954rr cracked crank case! adguy954 Honda FireBlade 7 05-16-2013 4:34 PM
cracked crank case on my 954??? adguy954 Honda FireBlade 55 01-17-2011 12:26 PM
How do i check a cracked engine case? FTP_929 General Discussion 25 10-24-2009 12:06 AM
98 900RR Cracked Engine Case cbr900rrjb Honda FireBlade 0 09-12-2008 4:09 PM
Bike knocked over, cracked engine case CBR Riding Fool General Discussion 13 01-28-2006 1:30 PM
