1998 RRW Charging issue? - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 03-30-2013, 3:35 PM Thread Starter
Reputation Power: 8
Hey all I have a 98 CBR900RRW with 84000 KMs last fall my battery puked all its contents out on the last ride of the season. I've since replaced it with a new one. Started the bike today and it's charging at 12.4v @ idle, 13.5v @ 3000rpm and 14.9v @ 5000rpm. So is my regulator fried? If so has anyone tried the "Caltric" stuff from ebay?
STATOR & REGULATOR RECTIFIER HONDA CBR900RR FIREBLADE 1996-1999 Motorcycle NEW | eBay
Thanks in advance.
Bubbamcf is offline
post #2 of 8 Old 03-30-2013, 8:10 PM
Re: 1998 RRW Charging issue?
Thanks in advance.
Measure the AC voltage on each of the three phases of the stator, perhaps you've dropped one.
post #3 of 8 Old 03-31-2013, 12:52 PM Thread Starter
Reputation Power: 8
Thanks I'll give it a check.
Bubbamcf is offline
post #4 of 8 Old 04-02-2013, 2:50 PM
Reputation Power: 34
The DC volts looks ok so as BR said check the AC volts. Can be you get the volts, but the amperage isn't there so things go wrong.
amorti is offline
post #5 of 8 Old 04-02-2013, 5:59 PM Thread Starter
Reputation Power: 8
OK checked the stator, all three wires have no continuity to ground or the case, wire to wire from the stator all have < 0.5ohms with each other. AC voltage is all identical idle is aprox 9-11v ac 5000rpm being 35-38v ac bike was at 150F. Plugged it all back together battery is at 12.30v dc at idle 5000rpm shows 13.8-14v dc now not 14.8v dc as before. So my question is this.. I had the battery boil over last fall. New battery now and everything appears ok, yet I am still leary to ride. What do u all think? Am I ok?
Thanks
Rick
Bubbamcf is offline
post #6 of 8 Old 04-02-2013, 6:56 PM
Thanks
Rick
Those are very low AC readings. Just to confirm, you did have the meter set to AC rather than DC?
I'd be checking that the rotor is magnetic all the way around it.
Has it ever crashed on the left side?
post #7 of 8 Old 04-02-2013, 8:06 PM Thread Starter
Reputation Power: 8
Ya meter was on AC. Bike was down on left side. Bottom of casing is ground some.
Bubbamcf is offline
post #8 of 8 Old 04-03-2013, 2:22 PM Thread Starter
Reputation Power: 8
OK so after more research, because google is way cheaper than ebay lol I found this youtube video
After watching the video I checked the stator the way he did ( I was putting one lead on the stator wire and the other to ground) I now have (all 3 phases are within a volt or two of each other) Engine temp 150F: Idle 17v AC ; 3000rpm 35v AC; 5000rpm 67v AC. Bike charges (DCv @ battery) idle= 12.7v; 300rpm=13.6v; 5000rpm=14.2-14.5v
So am I now to conclude that everything is normal and charging properly?
Thanks in advance
Rick
Bubbamcf is offline
04 CBR 1000rr Charging Issue jalford32 Honda FireBlade 5 02-05-2013 11:18 AM
charging issue, r/r question bd2454 Honda FireBlade 2 07-16-2012 8:26 PM
charging battery issue - 929 '00 gwech General Discussion 5 06-02-2011 12:42 PM
Charging issue KINDA tacmo0229 Honda FireBlade 3 04-12-2010 8:30 AM
Another charging issue....sheesh MACI4LIFE Honda FireBlade 1 06-26-2008 8:36 AM
