2000 CBR929RR rectifier questions - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 03-30-2013, 9:33 PM Thread Starter
Reputation Power: 7
Ok. Does my rectifier have to be firmly attached to the subframe for a good ground?
Also, can I directly connect the rectifier to my battery?
Here is my symptoms
It has done the same thing on two stators. I just don't want to spend some extra money on a rectifier.
2001 Honda CBR929RR Erion Racing Edition - Current
2001 Honda CBR600RR F4i Stunt bike - Current
2000 Honda CBR929RR Street Fighter - Parted out 8-2014
2006 Kawasaki Ninja 500R - Wadded Up 6-30-12
th3cavalry is offline
post #2 of 10 Old 03-30-2013, 9:45 PM
Re: 2000 CBR929RR rectifier questions
Here is my symptoms
Cbr 929 r - YouTube
No, the regulator doesn't need to be grounded, but attaching it to the frame helps it dump the heat.
Looks like the regulator is fine since it's stops the voltage going over 15V.
How much AC voltage are you getting on each phase of the stator?
Have you checked that the rotor is magnetic all the way around?
post #3 of 10 Old 04-01-2013, 9:55 AM Thread Starter
Reputation Power: 7
I haven't checked the rotor. Can I do the stator output test since its brand new and will that tell me if the rotor is bad?
post #4 of 10 Old 04-01-2013, 11:30 AM
Of course, I think we've advised you to measure the stator output perhaps half a dozen times now?
post #5 of 10 Old 04-01-2013, 11:32 AM Thread Starter
Reputation Power: 7
I thought it was just to test the stator... Sorry. I'll get this done today/tomorrow as soon as I'm around the bike
post #6 of 10 Old 04-01-2013, 11:45 AM
It is to test the stator, but if the stator reads very low then check the rotor with a piece of ferrous metal.
post #7 of 10 Old 04-01-2013, 11:48 AM Thread Starter
Reputation Power: 7
Come to think of it, when I changed out the stator I dont remember fighting with the cover taking it off or on. I remember my lil cousin saying something about he fought with his cover on his Hawk GT when replacing his stator and that he actually got a finger or something.
Mine came off real easy and i was able to set it back into place without trouble...
post #8 of 10 Old 04-04-2013, 6:40 PM Thread Starter
Reputation Power: 7
I get 10VAC at idle, then right around 30VAC at 5k RPM between each pen. Brand new stator. So I'd say the flywheel is bad?
post #9 of 10 Old 04-05-2013, 1:51 PM
Yeah that is really odd. I have changed mine 3-4 times and have always fought the magnetic pull to get it off and put it on correctly. You may have found your problem.
roughneckin is offline
post #10 of 10 Old 04-09-2013, 10:45 AM Thread Starter
Reputation Power: 7
i guess i know what to try next!
I did take a 4 hour trip(2 hours each way) in traffic my battery got real low and i had to push start the bike. but after 80 miles on an expressway running about 90 the entire way when I pulled up at home the battery was fully charged. so 5k+ rpms it will charge the battery if the headlight is off.
2000 CBR929RR im4u2nv81 For Sale 1 11-10-2007 12:05 AM
2000 CBR929RR GR8SHAG For Sale 1 07-08-2007 5:19 PM
2000 CBR929RR FS Blur929RR For Sale 14 07-30-2006 1:37 AM
Regulator/Rectifier 2000 CBR929RR For Sale seebeare929rr For Sale 0 09-28-2005 1:53 PM
WTS Regulator/Rectifier 2000 CBR929RR seebeare929rr For Sale 0 06-27-2005 6:05 PM
