954 headshake - Honda Motorcycles - FireBlades.org
post #1 of 2 Old 04-01-2013, 2:03 AM Thread Starter
954 headshake
So I think I discovered the dreaded 954 headshake that I've heard so much about. I was out carving up some corners yesterday getting some decent lean on the new tires. When exiting a turn after the apex with some throttle I started getting some pretty significant headshake. It happened about 3 times on my ride. Each time, I just backed off the throttle and it settled back down.
I started thinking about what could be causing it, and I thought maybe its due to the rear end squatting a bit and lifting weight off the front tire....does this sound plausible to you? Would stiffening up my suspension most likely solve this issue or could it be something else? I know getting a steering damper would help a lot, but I would rather fix this if possible rather than mask it.
What is it about the 954 that makes it prone to headshake?
"When you come to the end of your rope, tie a knot and hang on."
- Franklin D. Roosevelt
2002 954
maverick0716 is offline
post #2 of 2 Old 04-01-2013, 6:49 AM
Re: 954 headshake
Hi,
Ive got a 954. It seems to 'shake its head' a bit when I am accelerating out of a corner (really accelerating) and I put it down to being a light bike, with a short wheelbase, lifting its wheel a tad then coming down not quite square. Haven't had any that have worried me, though increasing throttle might help more than backing it off.
If its happening a bit, might want to check tire pressures, suspension and then if everything else is right, a dampener.
schnoogie is offline
What causes headshake? maverick0716 Honda FireBlade 31 04-01-2013 3:37 PM
Anyone have headshake on a 929? curt248 Honda FireBlade 46 07-08-2008 11:53 PM
A lot of Headshake plz help. CBR_MAN Honda FireBlade 42 08-17-2006 4:31 PM
929 Headshake Flycal6 Honda FireBlade 18 06-20-2006 1:21 AM
Headshake thebackdraft Off-Topic 11 07-31-2003 10:24 AM
