929 Diode stopped working - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 04-04-2013, 3:04 PM Thread Starter
I have a 929 that I have built from the ground up and I am currently trying to get it running.
I have no spark.
The diode (in the fuse box) is faulty. Apparently it should have continuity between outside and middle pins but mine has gone to ground.
I would like to know if other people have experienced a diode failure and whether this stopped the bike from running.
RobRed929 is offline
post #2 of 4 Old 04-04-2013, 6:09 PM
Re: 929 Diode stopped working
I have no spark.
I'm hopeless with electrics, but looking at the wiring diagram it seems to relate to the clutch and neutral switches? Are they connected?
https://www.fireblades.org/forums/att...ameuropean.jpg
post #3 of 4 Old 04-05-2013, 4:23 PM
Reputation Power: 29
i'm no leccy either. When u say "built from ground up" have u modified (butchered)the loom?
The diode simply passes earth from neutral switch to the dash neutral light (is this showing green light?) and earth to the starter. If u think diode plug is dead on both sides then jump both sides of box into centre with 2 bits of wire.
PEM-954 is offline
post #4 of 4 Old 04-06-2013, 9:04 AM Thread Starter
I have just replaced the Diode and now the ECU is giving MIL codes with the stand down.
The codes are 1. 9 and 14.
If I am understanding the Haynes manual then:
1. is MAP sensor wiring and will not stop the bike running.
9. is Air In take Temp (no sensor connected) - again should not stop it running.
14. is faulty No. 3 Injector or wiring. I think this is probably why I have no spark.
All intelligent comments welcomed!
Tach stopped working tigerclaw50 Honda FireBlade 6 10-02-2012 12:20 PM
929 fan stopped working FTP_929 General Discussion 5 11-17-2010 3:10 PM
Headlights suddenly stopped working SLEEPYDUB Honda FireBlade 3 09-05-2010 8:04 PM
my 2002 954 tach stopped working ???? quiknutz Honda FireBlade 2 08-23-2009 1:06 AM
Brake Light stopped working.. HELP Tempest929 Honda FireBlade 22 09-26-2005 9:35 PM
