929 No Spark and Fuel Pump Not Priming - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 04-07-2013, 4:35 AM Thread Starter
Help please!
Pulling out what little hair I still have!
929 RRY Built from parts - near completion and trying to get it running.
Engine cranks over great and everything electrical seems to work
EXCEPT:
No Spark (got a good spare plug in a coil resting on a good earth).
Fuel Pump not priming (tested the pump and it does work).
Only MIL error codes are 1 and 9 which are MAP sensor and Air Temp sensor which I don't think will cause knock-on problems?
Anyone got any more good ideas?
RobRed929 is offline
post #2 of 8 Old 04-07-2013, 6:42 AM
Re: 929 No Spark and Fuel Pump Not Priming
Originally Posted by RobRed929 View Post
Help please!
EXCEPT:
Is the ignition switch an OEM item?
Does it have HISS - if so, is it working? Can you swap in somebody else's ECU (you will need to trigger the sensor using their key) to confirm yours works?
Does the bank angle sensor work?
Are the fuses good?
Do you have continuity between the battery negative and the engine and frame?
Do you have power at the coils? At the coil harness connector?
Are you sure it's not Code19 - pulse generator?
post #3 of 8 Old 04-07-2013, 7:07 AM Thread Starter
Hi Bladeracer. Great to hear from you. Don't you sleep?
Ignition switch is OEM.
Got HISS which appears to be working (Key lamp lighting on dash).
No other ECU currently available to try.
Bank angle sensor working.
Fuses all good.
Perfect continuity all over engine and frame.
Codes are 1 and 9 Not 19.
Not sure about power at coils/ coil harness connector. - What voltage should be there? What's the best way to check?
post #4 of 8 Old 04-07-2013, 7:14 AM Thread Starter
Just remembered that I completely drained the engine oil.
Not a problem as I don't intend to run the engine at the moment but could the ECU block the spark and fuel if zero oil is present?
post #5 of 8 Old 04-07-2013, 7:37 AM
Fuses all good.
Yes, I sleep very often :-)
And the HISS light goes off when you put the key near the sensor?
I would think you should find battery voltage between ground and the positive terminals, with the ignition on of course.
Have you tried bypassing the kill switch to rule it out?
post #6 of 8 Old 04-07-2013, 7:38 AM
Another known problem with the 929/954 is the ground junction block within the harness can get corroded so that might be worth a look.
post #7 of 8 Old 04-09-2013, 4:26 PM Thread Starter
SORTED IT!
Thanks for your help and comments.
I took each multi-plug apart, cleaned both halves with a spray contact cleaner and carefully put them all back together. The fuel pump primes and I have a spark!
Today is a GOOD day!
post #8 of 8 Old 04-09-2013, 4:47 PM
Can any body help 929 fuel pump not priming last year servo went as they do I replace with 04 blade that fits and work last week went for mot passed put bike away for a week when I went to go out on it it felt like a block in the exhaust 1 mile up the road turned off engine. will not start pump not priming but not fi light flashing like before
riche is offline
f4i fuel pump not priming sportmotob Honda CBR 600 11 05-12-2015 2:53 AM
No fuel pump priming kleenf4i Honda FireBlade 2 09-09-2012 10:22 AM
929rr no spark, fuel pump is priming msf0002 Honda FireBlade 6 05-28-2011 9:31 AM
Fuel pump not priming ozerionblade Honda FireBlade 8 03-20-2008 8:22 PM
Fuel pump not priming - cause? cbr_df Honda FireBlade 60 01-10-2007 2:43 AM
