Worried I have overfilled oil - Honda Motorcycles - FireBlades.org
 1Likes
post #1 of 16 Old 04-22-2013, 9:05 AM Thread Starter
Reputation Power: 7
Hi Guys,
I serviced my new blade at the weekend and gave her an oil and filter change. The only thing is now I'm worried I've overfilled the oil
Looking at the measurements on the bottle of oil I think we put in just under 4 litres - probably 3.9 or something. Basically we warmed her up then drained the old oil. Filled up about 3.5 litres and then started her up for a few minutes, turned off and checked sight glass. We then topped up from there and kept repeating that process until oil could be seen in the sight glass. We continued the process until the level was just below the top line (as per Haynes Manual). Once I'd finished servicing her I went out for a spirited ride for a couple of hours.
I then checked the oil again last night after she had been sat all day and it seems to be above the top line and nearer to the top of the sight glass!
I'm now worried if I've overfilled it and if I've done any damage to the engine. I really don't fancy removing all the fairing to get to the plug just to drain a little so thought about putting a little pipett in the filler hole and sucking some up that way.
Do you guys think it's worth draining a little and would you say I should just stop worrying? I should mention she rides and runs perfectly fine.
Thanks,
Alex
alex350r is offline
post #2 of 16 Old 04-22-2013, 9:15 AM
Reputation Power: 113
Re: Worried I have overfilled oil
Did you check the level with the bike standing vertically, or on the sidestand? If you filled it to the line when the bike was on the sidestand, you've overfilled it.
Straight oil change should be about ~3 litres, or ~3.3 with a filter.
Sky91 is offline
post #3 of 16 Old 04-22-2013, 9:19 AM Thread Starter
Reputation Power: 7
Originally Posted by Sky91 View Post
Did you check the level with the bike level, or on the sidestand? If you filled it to the line when the bike was on the sidestand, you've overfilled it.
Nope we checked the oil with the bike level not on the sidestand. For some reason I thought it was 3.7 litres with a filter change. Guess I might have overfilled it then, what do you think to draining some out by the filler hole? Am I likely to have done any lasting damage? It's wierd because we got the measurement perfect with the bike vertical. I'm guessing when left overnight all the oil including any old stuff that was stuck in there has come to the bottom of the pan.
Thanks,
Alex
alex350r is offline
post #4 of 16 Old 04-22-2013, 9:32 AM
Quoted: 5 Post(s)
Reputation Power: 25
I don't think there is any issue with overfilling if you can see the level. It's when there is so much you can't tell the level that you're more likely to have a problem.
That having been said, no harm in taking a few ccs out through the drain plug if you're concerned.
The important thing is, don't sweat it. Everything is OK. Nothing's broken! Turn down the OCD a bit, LOL
ghbzorro is offline
post #5 of 16 Old 04-22-2013, 10:26 AM
morpheus266 is offline
post #6 of 16 Old 04-22-2013, 10:29 AM Thread Starter
Reputation Power: 7
Ok thanks - that reassures me a little I might see if I take a little bit out via the filling hole if possible.
Cheers
Alex
alex350r is offline
post #7 of 16 Old 04-22-2013, 11:39 AM
Quoted: 4 Post(s)
Reputation Power: 77
as well as level was the bike on a flat surface? Ive noticed when on a paddock stand effects the level needs to be both wheel on the ground and vertical.
You could blow some oil seals with too much oil but if you can see the top level its close, I would just take a little out, try a syringe to remove some with a rubber hose on if you cant be bothered to remove panels? They do them for brake bleeding perfect for this just dont lose the end in the engine!!
http://youtu.be/2ISgxtQXs9o
My 900RR Winter Project
Lambchops is offline
post #8 of 16 Old 04-22-2013, 10:45 PM
It wont hurt anything being half quart over, just drain it out. I bought my 954RR 2 weeks ago and it smoked at start up and under high rpms. After getting home I found the previous owner filled it on the side stand so it was a quart over, after draining the quart it was good to go.
N20zuki is offline
post #9 of 16 Old 04-23-2013, 12:22 AM
Reputation Power: 17
You can remove some oil pretty easy with a siphon. I overfilled my 929 once, and it was running a little different...I siphoned some oil out of the top plug, was kinda messy, but did the job, and got the oil back down to level I like (between both lines when bike is standing straight up)..and it ran better..or how I like it. I notice it affected the temperature being over filled a half quart or so.
CBRER is offline
post #10 of 16 Old 04-23-2013, 2:22 AM
Just remove the filter, pour the oil out of the filter and put it back. Easy way to remove some extra oil.
-tom-
FinnBlade is offline
post #11 of 16 Old 03-23-2017, 11:26 AM
Quoted: 6 Post(s)
Originally Posted by alex350r View Post
Hi Guys,
Thanks,
Alex
if you leftit over night the level would not have been a correct reading?need to be warmed up then let to settle for 5 odd mins..sorry to drag yet another old post up ,ive just filled mine up and a little worried about level myself as ive gone over th3e upper mark but have a gap ,only filled 3.3litres due to some old oil remaining ive been told..also been told this wont hurt as there is wiggle room on exact amount
Wevsky is offline
post #12 of 16 Old 03-23-2017, 11:46 AM
Heeza Y Zasch
unslow1's Avatar
Quoted: 372 Post(s)
Reputation Power: 56
dude this thread is almost 4 years old
unslow1 is offline
post #13 of 16 Old 03-23-2017, 2:52 PM
Quoted: 6 Post(s)
About as old as my oil then nah i thought rather than have yet another oil related post id actually search and comment on this.
unslow1 likes this.
Wevsky is offline
post #14 of 16 Old 03-23-2017, 8:46 PM
Quoted: 28 Post(s)
Suck a little out of the filler hole and get on with it.
jdoni is offline
post #15 of 16 Old 03-23-2017, 8:48 PM
Quoted: 198 Post(s)
I'm pretty sure almost four years later it is a non-issue.
lanbrown is offline
Overheat.....260 temp....should I be worried?? temperedtim929 Honda FireBlade 64 11-27-2016 2:44 PM
HONDA MECHANIC OVERFILLED MY OIL!! I NEED ADVICE!!!! lennybruce Honda FireBlade 40 06-13-2012 3:26 AM
worried & need pro advise ((FI light)) enimik Honda FireBlade 1 03-11-2009 10:45 PM
Worried that U can't pass that drug screen? Get this!! FB1000inPA Off-Topic 20 12-02-2008 4:46 PM
Should we be worried... Sunbert Off-Topic 6 08-03-2005 2:20 PM
