Fuel lines and neutral switch - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 05-05-2013, 3:30 AM Thread Starter
Hi hoping someone can help me with several problems which are all related. My problem is having a work place accident and stuffing up my shoulder I havent been able to ride my 1996 cbrr900rt for 3 years. I have decided to get it going and bought a new battery cleaned the air filter and she started fine, Then I noticed petrol leaking from the bike from the hose coming from on top of the carbies which goes from left to right around air cleaner then goes in a 90 degree bend then stops. There is a spare breather? at the back of the tank so I thought in my wisdom that maybe thats where the hose should be connected to. I came to start the bike today after charging and installing the new battery and it wouldn't kick over. I noticed the the neutral light did not come on. I removed the tank thinking I may have broken the wire and noticed the tank was empty. I removed the wire from the sender , shorted it and neutral light came on so I pulled the sender out to check it and petrol poured out from the switch. What have I done
tyson690 is offline
post #2 of 10 Old 05-05-2013, 8:34 AM
Quoted: 6 Post(s)
Reputation Power: 26
Re: Fuel lines and neutral switch
After 3 years your old gas is lumpy excrement. Remove and clean carbs and gas tank and all fuel lines.
Check your shop manual (you have one, right?) to change the connections back to the way they were, so that they are correctly connected.
ghbzorro is offline
post #3 of 10 Old 05-05-2013, 8:39 AM Thread Starter
G'day GH. It was fresh fuel. Tank was drained years ago. No I don't have a shop manual
tyson690 is offline
post #4 of 10 Old 05-05-2013, 8:49 AM
Quoted: 6 Post(s)
so it's time to get one.
happy to hear that it was all clean and dry during layup.
ghbzorro is offline
post #5 of 10 Old 05-05-2013, 8:52 AM Thread Starter
It still doesn't answer my question why petrol leaked from tank to inside motor/gearbox where neutral sender screws into
tyson690 is offline
post #6 of 10 Old 05-06-2013, 3:03 PM
My guess is that your float valves are stuck open and fuel is flooding straight through the cylinders into the engine.
Check your oil level.
post #7 of 10 Old 05-08-2013, 6:07 AM Thread Starter
Hi,
Thanks for the reply. My oil is full of petrol and like water. I have drained it added new oil but have not reconnected the tank as yet. Checking the needle and seat (float levels) was going to be my next project. Who would have thought that 8l of petrol would have leaked into the motor over 36 hours
tyson690 is offline
post #8 of 10 Old 05-08-2013, 6:20 AM
Hi,
I can tell you that your engine will be spotless inside now - it's actually quite nice stripping an engine that's had a gutfull of fuel just because everything is so clean :-)
When you pull the carbs off, connect fuel to them, hold them as they would be positioned on the bike and see if they leak. Then tilt them in each direction until they do leak, then back to level and confirm they stop leaking. In near-twenty-year-old carbs I would just replace them.
post #9 of 10 Old 05-08-2013, 6:25 AM Thread Starter
Thank you will do and let you know the outcome
tyson690 is offline
post #10 of 10 Old 06-08-2016, 1:43 PM
Did you find and fix the cause of this?
I have just had exactly the same experience.
Update- My bike had also been laid up for a few years, and I had the exact same issue with the neutral switch / light, and a petrol / oil mix flooded out when I removed the neutral switch too.
I had cleaned the carbs and got it running again, but looking around the forums and elsewhere it seemed the cause was likely to be a stuck float / float valve. I took my carbs apart and re-cleaned them again and noticed that the plunger in the valve on 2 of the carbs was stuck and did not depress. A bit of carb cleaner and force and they now spring up and down again.
I put the bike back together, drained the oil and put fuel in the tank with the tap on, and the sump plug out, and left overnight.
No fuel had leaked overnight so hopefully this has resolved the issue.
GaryP is offline
98 900RR, need to know where all fuel and vacuum lines go relliMmoT Honda FireBlade 8 05-23-2013 5:54 AM
Neutral Switch Issues - 97 CBR900 Tupp Honda FireBlade 13 04-15-2013 4:00 PM
neutral safety switch??? cody5127 New Rider Orientation 4 08-10-2012 12:39 AM
Fuel pump or clogged fuel lines??????? pizzario69 General Discussion 1 09-28-2009 5:16 PM
neutral and fuel warning light wires - cbr 954 abelg Honda FireBlade 4 06-16-2009 10:06 AM
