Cbr 929 bogs down under hard acceleration - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 05-14-2013, 11:45 PM Thread Starter
I've recently bought a used 2001 cbr 929 that was used and abused from some teenAger that had no idea what he was doing. So now I'm in the process of trying to resurrect it.
So my problem is that under hard acceleration, my bike will bog down like its not getting enough fuel. 1st through 6th gear. Especially if I pop the clutch. It will sound and feel like its out of fuel but if I hold it wide open for a few seconds, it catches itself and takes off. Also, if its in neutral and I rev it up, 50% throttle movement is relevant to 9000rpm and anything after that it starts to bog.
I'm getting a code 11. And the bike has 24xxx miles. The exhaust valve is bypassed and secured in the full open position
Thanks. Tony
Tonyhenschel is offline
post #2 of 11 Old 05-14-2013, 11:48 PM Thread Starter
Re: Cbr 929 bogs down under hard acceleration
Oh and also, sometimes when I let it sit for a bit, I have to flip the kill switch a few times to prime the fuel pump to build up the pressure
post #3 of 11 Old 05-14-2013, 11:52 PM
Thanks. Tony
At exactly what RPM does it bog down?
Do you mean it won't rev over 9000RPM in neutral?
Code 11 is the speed sensor but has no effect on the engine.
post #4 of 11 Old 05-14-2013, 11:53 PM
I don't understand what you're saying here.
Build the pressure up to what exactly?
post #5 of 11 Old 05-14-2013, 11:54 PM Thread Starter
It varies, but usually right around 7-8k
And yea, in neutral it won't rev over 9k same thing with the clutch pulled in.
post #6 of 11 Old 05-15-2013, 12:00 AM Thread Starter
In my head, the fuel line needs to supply pressure to the injectors and fuel pressure regulator. But that's just my exhausted mind trying to make sense of the situation.
post #7 of 11 Old 05-15-2013, 12:04 AM
Sure, but what makes you think you need to prime the rail more than once?
post #8 of 11 Old 05-15-2013, 12:07 AM Thread Starter
Because if i dont prime it a few times before i start it then i need to crank it over for about 10 seconds before it will catch. Where as if I prime it a few times it cranks right up.
post #9 of 11 Old 05-15-2013, 12:08 AM
Have you checked the fuel pressure regulator vacuum hose is not passing fuel?
post #10 of 11 Old 05-15-2013, 12:12 AM Thread Starter
I have not. Although I'm fairly sure it does leak.
post #11 of 11 Old 05-17-2013, 2:54 PM Thread Starter
The fuel pressure regulator does not leak, but when I propped my tank up, I noticed that the fuel line coming off of the fuel pump was kinked a little. Straightened that out and now it runs great! I appreciate the help though!
White exhaust smoke under hard acceleration Sportbike_Mike Honda FireBlade 5 03-16-2013 8:28 PM
Bogs down at 6kish livinloud11 Honda FireBlade 8 08-17-2011 12:24 AM
Rattle between 3k and 4k rpm under medium/hard acceleration jamomac Honda FireBlade 4 05-28-2011 11:19 AM
HELP!!! 600 bogs down lokey22 Honda CBR 600 4 06-21-2009 10:06 PM
'02 RC51 F1 Light on under hard acceleration solaidrider667 Honda RC51 8 10-09-2007 3:40 PM
