954 stalling - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 05-14-2013, 8:50 PM Thread Starter
954 stalling
need help ... don tknow where to post this .. but my 954 is having some problems .. when i pull on the throtle it is stalling for a few seconds then reving up .... the red light is bllinking the f1 signal is present a oil icon also ..... mking noices sonds like a harley please help !!!
jalfaro3.14 is offline
post #2 of 11 Old 05-14-2013, 11:57 PM
Re: 954 stalling
At exactly what RPM is it stalling?
Count the long and short flashes to get the code.
Is the oil level fine?
post #3 of 11 Old 05-16-2013, 9:24 PM Thread Starter
Re: 954 stalling
see as soon as i try to get it out of 1st gear like the gas isnt getting through ...
post #4 of 11 Old 05-16-2013, 10:30 PM Thread Starter
Re: 954 stalling
Originally Posted by kartl View Post
It could be a busted injectors... As bladeracer get the error code and lets see what we can do.
sounds expensive could it be like a fuel filter maybe ... (yn)
post #5 of 11 Old 05-17-2013, 2:52 AM
Quoted: 120 Post(s)
Reputation Power: 198
Re: 954 stalling
How much work can you do on your bike?
FI light is actually the MIL. Malfunction Indicator Lamp.
Can you jump the service connector to get the codes to flash on our MIL?
If the oil light was lit while the bike was running, that's not good.
Last I checked, 954's don't sound to much like a Hardly Ableson, so that's not to good either.
jondog9 is offline
post #6 of 11 Old 05-18-2013, 2:51 PM Thread Starter
Re: 954 stalling
yes i think its the fuel filter or fuel injector..... i put fuel injector cleaner and its sounding better i just cant spend too much right now.. hopefully that does the trick ...
post #7 of 11 Old 05-18-2013, 3:35 PM
Quoted: 120 Post(s)
Re: 954 stalling
In your first post you said you had a blinking MIL. You also said the oil light was on.
Fuel has nothing to do with those symptoms.
When you go to start the bike now, when you turn the ignition to on, does the MIL blink?
It should come on momentarily, along with the oil light, then both should go off and stay off after the fuel pump stops self priming. About 2 seconds.
Then with the sidestand down, start the bike.
What does the MIL do?
You may also have a failing fpr-fuel pump regulator.
To check it, lift the tank, pull the small vac hose off, turn the key to on so the pump will prime, then look for any leaks from the fpr.
I'm interested to know about the MIL...
jondog9 is offline
post #8 of 11 Old 05-18-2013, 4:17 PM Thread Starter
Re: 954 stalling
it doesnt blink anymore ...... now its just a red light ... and f1 light ..
post #9 of 11 Old 05-18-2013, 9:38 PM
Quoted: 120 Post(s)
Re: 954 stalling
The MIL is the FI light
The Malfunction Indicator Lamp will light up when there's a code for the Fuel Injection system.
So the FI light comes on when you start the bike, right?
Does it blink, or just stay on solid when the bike is idling and it's resting on it's kickstand?
jondog9 is offline
post #10 of 11 Old 05-18-2013, 9:46 PM Thread Starter
Re: 954 stalling
just stays on
post #11 of 11 Old 05-18-2013, 10:12 PM
Quoted: 120 Post(s)
Re: 954 stalling
And the bike idles normally?
Have you jumped the service connector for codes?
Do that.
Write down all the codes that appear.
Then clear the codes.
Then start the bike on it's sidestand and see what the FI light does.
The manual shows that a solid lit FI light indicates a service connector short, or a faulty ECM.
Do you know anyone that will let you swap their 954 ECM just to see how the bike acts?
Do you have a Power Commander? Bypass it if you do.
jondog9 is offline
Stalling while riding Dantheman0616 General Discussion 4 07-05-2012 7:19 PM
RC51 Stalling TripleC Honda RC51 13 05-12-2012 8:30 PM
94 honda cbr 600 f2 stalling lab4x4 General Discussion 5 07-15-2008 11:53 PM
06 GSXR600 Stalling Out!!!! elijahblake Suzuki Motorcycles 3 08-12-2007 10:22 PM
