Brake disc/rotors cbr1000rr6 fitment - Honda Motorcycles - FireBlades.org
post #1 of 1 Old 05-15-2013, 11:31 AM Thread Starter
Hi all, new to the forum and i have a question regarding the fitting of brake disc/rotors on my cbr1000rr6 blade.
I have a warped disc on the front and i am deciding to replace both, i would like to know if a set of front discs/rotors from a 2008/9 blade (non ABS type) will fit on a 2006 blade?
I have done a little research and all measurements seem the same,
disc diameter 320mm
bolt pattern 110mm
inner diameter 94mm
offset thickness 12mm
Have i missed any other critical measurements as they both have the same results which in theory means they will fit on my 2006 blade.
faddy06ftm is offline
wanted 954 Rotors brake Disc 954_RR Wanted 4 08-26-2010 8:54 PM
Need rotors for 93 900rr or fitment suggestions jptechnical Honda FireBlade 3 04-24-2009 7:28 PM
Wanted: Front Disc Rotors Bear Wanted 3 09-30-2005 3:39 AM
Disc Brake Clean up Sliwa General Discussion 2 10-04-2004 11:13 AM
warped brake disc puggy Honda FireBlade 5 08-25-2004 9:35 AM
