Won't rev past 7k..... - Honda Motorcycles - FireBlades.org
post #1 of 1 Old 05-16-2013, 1:38 PM Thread Starter
Quoted: 3 Post(s)
Reputation Power: 11
Allow me to start at the beginning....
I commute to work, about 100 miles a week.
About 6 weeks ago, I noticed when starting the bike from cold, it would crank for about a second, then silence, whilst it was silence I still had my finger on the button, and I could hear fuel being squirted from the injectors, then, about 3 seconds later it would catch and she started, and everything was fine, she rode fine and everything, its worth stating that this happened about 80% of cold starts.
About 2 weeks ago, I removed the air box flapper, and I noticed the positive difference in low down acceleration, no negative effects.
About 1 weeks ago I found a split in the fuel return hose, only small, so I replaced the hose with another, exactly the same.
After, this fuel hose replacement, the bike is very hard to start from cold, keeps cranking for about 5 seconds, then starts to catch, and splutter a bit, 3 or so seconds later, finally catches, then all is ok.....or so it appeared.
Today, it wouldn't rev past 7k, up to 7k is fine, then it immediately bounces from 7k downwards, like its hit some invisible limiter!
Also, when I replaced new return hose, and attached main hose, I re-fuelled tank, turned on ignition, as the pump primed, it squirted out some fuel from the fuel rail banjo hose side because I forgot to tighten it up!
Could this have created some kind of air bubble causing this issue?
Are any of these issues related?
And if not......why not?
Hawkes is offline
HELP! My bike will not rev past 8k. la95900rr Honda FireBlade 15 08-20-2015 12:29 AM
Should Obama's Past be a Concern? denzee Politics 61 10-23-2008 7:53 PM
2008 past away at only 4 months sweet1070 Wrecked Motorcycle Photos & Stories 8 09-17-2008 7:14 PM
How to cope with a past crash Hammer Track Days / Riding Schools 49 06-05-2006 7:58 PM
Past TV shows... showmethebombs Off-Topic 46 07-20-2005 5:14 PM
