ok, help please! I think i flooded the 929 now it's not wanting to start! - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 05-17-2013, 5:33 PM Thread Starter
Quoted: 3 Post(s)
Reputation Power: 25
I needed to fix my throttle, it was sticking a little! I went to start it, didn't notice that the throttle was fully open when I tried to start it! it started a little then died it! from what I have found, I have to pull the spark plugs out and let it sit for a few hours??? what a pain!!!!!!! can I just wait a little bit! guess who got some cable lube! guess I can put the new spark plugs in now may be thro in some 954 injectors, and throttle body's too! any way, there are no codes ect!
tweezy666 is offline
post #2 of 11 Old 05-17-2013, 5:50 PM Thread Starter
Quoted: 3 Post(s)
Re: ok, help please! I think i flooded the 929 now it's not wanting to start!
ps if I get the 954 throttle body's and injectors. would a pc3 make it a lot better??? or is it just so you can fine tune it? If I keep the bike all get a pc3 at some point! if it makes a huge diff all get one now!
post #3 of 11 Old 05-17-2013, 6:44 PM
Quoted: 2 Post(s)
Reputation Power: 15
didn't know you could flood a FI engine, but i just looked it up and yes, you can. learn something new every day. when i have flooded an engine in the past, waiting about an hour (sometimes less) has always got me back up and running. never removed a spark plug, although that would probably help it go faster.
packman5280 is offline
post #4 of 11 Old 05-17-2013, 6:58 PM
Reputation Power: 22
I don't think you can flood an FI engine. I bet the OPs issue is a different kind of 'flooding' than what you see with carbed engines.
Unlike carb jets, injectors won't 'squirt' unless the engine is running because there is no mechanical linkage between the throttle and the injectors themselves.
Sportbike_Mike is offline
post #5 of 11 Old 05-17-2013, 7:00 PM Thread Starter
Quoted: 3 Post(s)
yea not sure if waiting gonna work all that well
post #6 of 11 Old 05-17-2013, 7:16 PM
Quoted: 2 Post(s)
google it. if you turn the engine over a long time and it doesn't start for some reason, you've just squirted a bunch of fuel into your cylinders. ie, flooded the engine. a spark plug wet with fuel does not spark. wait an hour, it will dry out, try again. or, don't.
post #7 of 11 Old 05-17-2013, 7:17 PM
Reputation Power: 113
I've done it a couple of times by switching the ignition on and off a few times while doing some electrical work (thus injectors firing a few shots when priming). I don't think it'll happen by holding the throttle open when pressing the start though.
Sky91 is offline
post #8 of 11 Old 05-17-2013, 7:26 PM
Quoted: 2 Post(s)
are the injectors not firing when the engine is cranking trying to start?
post #9 of 11 Old 05-17-2013, 11:25 PM Thread Starter
Quoted: 3 Post(s)
it could have been the cause to0, I think I did that as well! the throttle had been sitting there all day, wide open!!!
what did you do sky??? take the spark plugs out, wait a hour that's what I have read!
post #10 of 11 Old 05-18-2013, 5:53 AM
Just wait a bit. Might take a bit longer to start. Don't hold down the start button for more than 5 seconds or so at a time though.
Sky91 is offline
post #11 of 11 Old 05-19-2013, 3:16 AM Thread Starter
Quoted: 3 Post(s)
still not wanting to start! damn!!!!!! guess i'm taking the stark plugs out tomorrow if it's not starting in the am! I'm getting the 954 throttle body's and injectors too!!!! yea
Flooded Carbs, Dying Bike gradymitchell General Discussion 3 08-13-2012 12:19 AM
900RR Flooded Real Bad kol Honda FireBlade 7 11-19-2010 8:48 PM
New guy here wanting to say hello!!! coker98 Introductions 3 10-01-2007 8:27 PM
WANTING: 2001 929 RAM AIR KIT 929gofast Wanted 2 05-08-2007 3:34 PM
954 Flooded Hammer Honda FireBlade 17 02-17-2004 12:00 AM
