to pc3 or not to pc3 that is the question??? - Honda Motorcycles - FireBlades.org
post #1 of 13 Old 05-20-2013, 3:38 PM Thread Starter
Quoted: 3 Post(s)
Reputation Power: 24
well I order the 954 throttle body's and injectors!!! will it give me a big jump in power or how the bike runs??? or anything but being able to mess with the power ban and what not, if I where do get a pc3??? will it run better??? give me more hp maybe too that would be nice :-) any way please some one let me know!!!
tweezy666 is offline
post #2 of 13 Old 05-20-2013, 3:54 PM Thread Starter
Quoted: 3 Post(s)
Re: to pc3 or not to pc3 that is the question???
O do I need a 954 are box for the throttle body's and injectors??? I have been told that???
post #3 of 13 Old 05-20-2013, 4:20 PM
Are you trying to put these on a 900RR (as per your profile)?
post #4 of 13 Old 05-20-2013, 4:32 PM Thread Starter
Quoted: 3 Post(s)
no no my 929 :-) I have 3 bikes!!! a 94 900rr, 2001 929 and a 1986 intruder vs700
post #5 of 13 Old 05-20-2013, 4:38 PM
Okay :-)
In that case, I would get a PC3 whether you swap the TB's or not.
No, you don't need the 954 airbox or stacks.
post #6 of 13 Old 05-20-2013, 4:47 PM Thread Starter
Quoted: 3 Post(s)
Okay :-)
why is that??? dose the pc3 make the bike work better, IE have less issues ect! all ready ordered the 954 stuff!!! 65$ can't really loose!!!
so I don't use the stacks, I just pull ever thing off, toss it on the 929 stacks??? these are my 954 throttle body's and injectors!!! what wire do I need??? can I buy a new one from Honda??? don't want to buy the whole 954 wiring harness!!!
post #7 of 13 Old 05-20-2013, 9:39 PM Thread Starter
Quoted: 3 Post(s)
well I got the pc3!!!!!!!!! so it's just plug and play right! I think it's been mapped it's off a 929!
post #8 of 13 Old 05-20-2013, 9:40 PM
Quoted: 120 Post(s)
Reputation Power: 198
The PCIIIusb is the way to go. It allows you manipulate any or all of the cells in the fuel map.
You'll feel a noticable difference in how smooth the throttle response is - when properly mapped. That's the catch. You can experiment with download maps, lots of free ones out there, but you really need to take the bike to a dyno and get a custom map done for your bike. Then it'll run at it's optimum.
jondog9 is offline
post #9 of 13 Old 05-21-2013, 6:23 AM
Reputation Power: 113
Even then, a downloaded map is better than the stock ECU settings.
Sky91 is offline
post #10 of 13 Old 05-22-2013, 11:36 PM Thread Starter
Quoted: 3 Post(s)
my pc3 do I need to get a o2 sensor??? I don't think my bikes from cal! so I shouldn't need one right!!! this is my power commander 3
post #11 of 13 Old 05-23-2013, 12:53 AM
Quoted: 120 Post(s)
Make sure you hook the small black wire to the battery post -Ground.
No oxygen sensor needed.
Is that a serial port or usb?
You'll find out what map is on the Power Commander when your hook your laptop up to it.
You also need to go to DynoJet.com and look up for the free software download so you computer has a program to work with the power commander unit.
Here's the thing that I see with your setup. You're increasing the throttle body size, right? Are the 954's bigger? better or more jetting? increased fuel rate?
I don't know, that's why I'm asking, but nonetheless, you're modifying the fuel consumption of your engine, of course you have to match the fuel map to compensate. That's exactly what the PC will try to do. It's up to you to load the right map. Whether it's a canned map or a dyno tune, you need different fueling. If you want to go by seat of your pants feel, than experiment with the different maps out there, if you want to take the guessing game out of it and make sure your bike is running really proper, then go to a dyno. A reputable one. Do a little research.
jondog9 is offline
post #12 of 13 Old 05-23-2013, 3:49 AM
It's a serial unit.
While a dyno will give you the perfect map _for running on the dyno_, a "seat of the pants" map is quite capable of giving you a perfect map for actual riding ;-)
post #13 of 13 Old 05-23-2013, 12:05 PM Thread Starter
Quoted: 3 Post(s)
It's a serial unit.
I pretty sure it's serial unit! as all ways thanks guys! I will try to get it mapped, but I just got a big hole in my 94 900rr back tire last night! so it may be rushed into services!!!!!!!!
Clutch question / judder spring question on a 929 ceramicsdude Honda FireBlade 3 09-25-2015 3:37 PM
F4i Question ... Where's main Fuse and blinker question.. Dmat1987 Honda CBR 600 3 02-15-2009 9:20 PM
HTEV Eliminator Question & K&N Question Magnum70 Honda FireBlade 2 03-30-2006 9:48 AM
Question for IT guys (Source Control Question) Pulse Off-Topic 7 12-19-2003 8:49 AM
