Stator replacement - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 05-21-2013, 3:45 AM Thread Starter
Stator replacement
So I went to replace my stator because my new batter went dead after one ride, and after I took the fairings off, the next step is to disconnect the white connector by the battery. The three prongs on the male side connector had one of them black and the plastic was partially melted. I'm thinking this is the problem with the battery and stator. What would this be caused by?
krtalian is offline
post #2 of 6 Old 05-21-2013, 6:14 AM
Re: Stator replacement
I would guess it is caused by a bad connection due to dirt and or corrosion between two of the pins. Such a bad connection will have increased resistivity and cause increased power dissipation and temperature.
It might possibly also be caused be a faulty stator causing excessive current flow in one of the 3 wires but I do not have sufficient details about the regulator circuitry to say if this is a probable cause. Maybe other on the forum knows?
:-) ... Fred
FireBladerDk is offline
post #3 of 6 Old 05-21-2013, 6:16 AM Thread Starter
Interesting, I'll have to think about that one, I'll have to replace the piece, and figure out how to test if anything else was shorted in the charging system.
krtalian is offline
post #4 of 6 Old 05-21-2013, 7:07 AM
You might find this article worth reading:
Alternator Tutorial - Motorcycle Do It Yourself Article
:-) ... Fred
post #5 of 6 Old 05-21-2013, 10:30 AM
Reputation Power: 51
Basically, they all do it, or will be doing it right now. Quite a bit of current flows from alternator to rectifier, any resistance in the connection generates heat, this both burns the connector/s and melts the plastic. Well worth keeping an eye on the connectors general condition and keeping it clean. In the worst cases cutting the connector out and soldering the three wires together gives a reliable repair.
jdugen is offline
post #6 of 6 Old 05-21-2013, 2:23 PM Thread Starter
So you're saying take the plug out completely and solder the wires together. I guess I could get some new connections and solder them on instead.
krtalian is offline
2005 CBR1000rr stator replacement (HELP) Revenge88 Tools / Garage / Paddock 1 03-24-2013 1:21 AM
Alternator (Stator) Cover Replacement slickwill How To Articles 23 08-16-2011 9:34 PM
Stator Replacement CBR 900RR 1998 JJL827 Honda FireBlade 1 07-02-2010 12:41 AM
Stator cover replacement help mar10w6 General Discussion 2 06-24-2010 12:27 PM
Stator Replacement? seebeare929rr Honda FireBlade 11 04-08-2005 10:30 PM
