93 cbr900 rrp frontfork problem - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 05-21-2013, 10:17 AM Thread Starter
hi everybody!! first of all,,.. excuse me for my poor englise!;-) thanks,. i have a problem some i hope you will help me wth! now: i have a stability prob. on my bike, almost so i have a "hinge" on middle if the bike, when driving slow its heavy on turns,and fast so is it almost impossible to steer right ahead,all over the place, sag in front and rear are 30mm. i can info you that i have change steering steam(tapered rolling) and i have change oil and fork buishing + buish slider in both forks ! oil is motul 10. wonder wath is going on here! help is needed! thanks and best regards
netromcbr is offline
post #2 of 10 Old 05-21-2013, 12:50 PM
Re: 93 cbr900 rrp frontfork problem
First, have you ridden other 900RR's to confirm there is a problem with yours?
Are your tyres in good condition, properly inflated, and the proper profiles?
Are your wheel and swingarm bearings okay?
Has either end of the bike been lowered or raised?
post #3 of 10 Old 05-21-2013, 1:40 PM Thread Starter
thanks for youre answer well ,ok bearings front and back,tyers are ok, only one notis on front tyer: its sliktly more vear one left side than right side!? psi in front are 36 and rear is 42 psi! rear svingarm are fine, so i wonder wath so going on here. thanks and sorry for my englise!
post #4 of 10 Old 05-21-2013, 1:45 PM Thread Starter
yepp! i have ride other cbr900, mine work fine too before i change steering bearing!?! bike are not lowered either rear and front!
post #5 of 10 Old 05-21-2013, 3:10 PM
Quoted: 4 Post(s)
Hi, I think you might of over tightened the head race bearing, just slacken them off a little.
BLOB748 is offline
post #6 of 10 Old 05-21-2013, 3:12 PM
You mentioned it was fine before you changed head bearings, maybe you did not seat the races correctly in frame? or you may have over tightened them?
stevecbr1000 is offline
post #7 of 10 Old 05-22-2013, 4:08 AM Thread Starter
hi! i think you are right! i will investigate that! it is not over tightned but maybe i hasent got the seat races correctly! but ,if so vouldnt there be some slark in the bearings?
post #8 of 10 Old 05-23-2013, 12:46 PM Thread Starter
thanks Stevecbr1000. you got it right. bearings wasent seated propely, fix it and now is bike "normal" to drive! thanks again and best regards Morten
post #9 of 10 Old 05-24-2013, 4:19 PM
Hei Morten
Kjekt se andre nordmenn p forumet!
noguneil is offline
post #10 of 10 Old 05-24-2013, 4:45 PM
Your welcome mate, glad to help.
94 CBR900 Starter Relay Problem tnorth General Discussion 4 06-03-2012 9:19 PM
CBR900 RR-P Problem rear end. Please Help! Milzy General Discussion 25 09-12-2011 9:08 AM
ADVICE: 99 cbr900 electrical problem. Eating batteries ads Honda FireBlade 3 10-12-2010 9:48 PM
tachometer problem cbr900 99 (919) fernandosma Honda FireBlade 0 12-08-2007 7:57 AM
CBR900 Starting problem (PLEASE HELP) :( BladeboyCBR900 Honda FireBlade 19 05-09-2007 9:21 PM
