'00 929 Rich - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 05-21-2013, 11:25 AM Thread Starter
Reputation Power: 7
'00 929 Rich
Ok, now that I fixed my charging issue(replaced the flywheel), its now time to dig into why I'm running rich. Heres what I can tell you.
1) The airbox is missing some screws so its not tight.
2) The plugs are new, maybe have 1k on them.
3) Full Two bro exhaust, header, midpipe, and can. The header to midpipe connection is loose, haven't tightened that, and the midpipe to can is loose, and you can see where some exhaust has leaked(due to black on the midpipe)
4) no power commander
5) The FPR is fine. Doesn't leak and the vacuum hose does not have any fuel.
2001 Honda CBR929RR Erion Racing Edition - Current
2001 Honda CBR600RR F4i Stunt bike - Current
2000 Honda CBR929RR Street Fighter - Parted out 8-2014
2006 Kawasaki Ninja 500R - Wadded Up 6-30-12
th3cavalry is offline
post #2 of 7 Old 05-21-2013, 1:01 PM
Re: '00 929 Rich
What indicates you're running rich?
I would guess the missing PC is the likely culprit here.
What is your fuel economy like?
post #3 of 7 Old 05-21-2013, 3:22 PM Thread Starter
Reputation Power: 7
Re: '00 929 Rich
Well, black smoke on initial start up, exhaust smells of unburnt fuel. Its rich enough that the scent is on my clothes and have numerous people ask me wtf is that smell. I'm also getting less than 100 miles before fuel light comes on. Im used to working on fords so I know what rich smells like
post #4 of 7 Old 05-21-2013, 3:23 PM
Re: '00 929 Rich
That all sounds like the fuel pressure regulator to me.
post #5 of 7 Old 05-21-2013, 3:33 PM Thread Starter
Reputation Power: 7
Re: '00 929 Rich
I've checked, no fuel coming out of it or a wet vacuum line. I've even took a mechanical vacuum pump pumped it up a few psi and primed the pump, and even started it, reved it up and no fuel out of the fpr at all
post #6 of 7 Old 05-24-2013, 4:15 PM Thread Starter
Reputation Power: 7
Re: '00 929 Rich
any ideas?
post #7 of 7 Old 05-24-2013, 4:37 PM
Quoted: 2 Post(s)
Reputation Power: 37
Re: '00 929 Rich
You definitely need to re-map with a full exhaust, and that's where the PC comes in. I would try that first and see how it runs. Did you replace/remove the air filter as well?
Lobsta13 is offline
Other than FPR what causes a 954 to run rich? BLouder Honda FireBlade 14 08-08-2014 8:13 PM
954, running rich, sconi Honda FireBlade 17 10-05-2010 8:59 PM
RIP Rich (RAH-VFR) CBR929RE General Discussion 10 07-05-2007 4:16 PM
Help - F4i Running Rich backendoforever Honda CBR 600 5 06-24-2007 1:20 AM
954 Running Very Rich Gruvin2 Honda FireBlade 2 06-20-2007 6:45 PM
