1993 900rr seat bolt size/pitch - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 06-04-2013, 12:26 PM Thread Starter
I am slowly restoring/putting together a 1993 900rr. I have a snapped bolt in one of the seat holes, and the other missing. Since I can't drag the frame to home depot to figure out the thread pitch and size, I've been trying randomly with no luck.
Was hoping someone might have the correct info so I can get a bolt extractor/tap and find two new bolts to secure the seat on?
Thanks a ton!
rice_rocket is offline
post #2 of 6 Old 06-04-2013, 12:30 PM
Reputation Power: 113
Re: 1993 900rr seat bolt size/pitch
Ron Ayers fiches
Sky91 is offline
post #3 of 6 Old 06-04-2013, 12:35 PM Thread Starter
I'll try to look it up. I got a large pdf of a 900rrparts for a 98 fireblade, the frame diagram does not actually list the part for the bolts to hold on the seat, but every single bolt to keep the frame together. Maybe I overlooked it, but couldn't find it.
post #4 of 6 Old 06-04-2013, 1:06 PM
Reputation Power: 34
M6. I'd have to check the length, or check your fiche again.
To get it to fit securely you'll be wanting the two tophat washers too.
amorti is offline
post #5 of 6 Old 06-04-2013, 2:11 PM
devildog4evr's Avatar
Quoted: 29 Post(s)
I've got a '94 parts list and it calls for a M6X20.
devildog4evr is offline
post #6 of 6 Old 06-04-2013, 2:16 PM Thread Starter
Thanks a ton, I'll go get an M6 and try it out.
I went through the pdf I had and found mention of a bolt. It is a "Honda 6X20" bolt which I found online at a place for $0.75 so I ordered two.
Ooops I see that I got the response before I submitted my reply. M6X20 it is! Thank you!!
1993/94 F2 front brake double banjo bolt yogisays09 Honda CBR 600 2 03-20-2013 9:35 AM
929 Frame bolt size? blademcb Honda FireBlade 1 06-21-2011 12:23 PM
rear fender bolt thread/pitch 2005 cbr 1000rr submarine Honda FireBlade 2 06-28-2008 6:14 PM
Bolt size for spool kinkeringkong Honda FireBlade 4 01-10-2006 11:25 PM
What is the bolt size for a bolt-on stand? Bdonkadonk74 Honda FireBlade 7 03-11-2004 2:24 AM
