Buffeting issue. - Honda Motorcycles - FireBlades.org
post #1 of 14 Old 06-04-2013, 10:08 PM Thread Starter
Reputation Power: 7
Buffeting issue.
I noticed today on the way home from work that my 2002 954RR had some severe buffeting at certain speeds....will not go into detail because forum does not want to promote illegal things which is understandable and I respect it...just say...WELL above the speed limit....near top speed...I had some bad buffeting.
Is this common in the 954's or is it something that can be adjusted out or diminshed with mods?
Edit:
BTW...it has stock mirrors and a double bubble windscreen.
Monolith is offline
post #2 of 14 Old 06-05-2013, 1:37 AM
Re: Buffeting issue.
Edit:
What exactly do you mean by "buffeting"?
Was it widy or gusty perhaps?
post #3 of 14 Old 06-05-2013, 5:22 AM
Reputation Power: 34
Te double bubble screen could be your issue if too high. Or if you aren't tucked in tight enough. Or if there was a noticeable crosswind. Or it could be normal depending on how bad it was and how accustomed you are to doubling the speed limit. It's really wry fast and the aerodynamics become quite important, air is really thick at these speeds.
amorti is offline
post #4 of 14 Old 06-05-2013, 6:26 AM
Reputation Power: 113
Was it the bike, or yourself that was being buffeted?
At high speed there's a huge pressure difference between the outside of the bike, and the area just behind the screen. As you had your head in that area, that's probably what was buffeting you around.
Sky91 is offline
post #5 of 14 Old 06-05-2013, 10:36 AM Thread Starter
Reputation Power: 7
My head was not buffeting...my shoulders did a little...it was mostly the front of the bike. My left mirror folded in first...then the side to side buffeting started.
I could feel the difference in pressure you spoke of...I was tucked in the best I could but my shoulders were out a little...I was slid back in the seat hugging the bike but being I'm 6'3" tall and 250 even the double bubble cant cover it all lol.
It was my first time going that fast...and feeling that made me wonder how those guys at Isle of Man TT do it..cause to be honest...it scared the **** out of me.
Monolith is offline
post #6 of 14 Old 06-05-2013, 10:50 AM
Quoted: 2 Post(s)
Reputation Power: 37
I'm 6'5" 265lbs and have a double bubble and it's hard to get completely out of the stream. I hit 165 pretty regularly at Mid-Ohio and the wind is intense, but nothing unusual, so it could just be that you are not used to it.
It's a lot of fun slowing down from those speeds for turn 7.
MidOhio trackmap.jpg‎
Lobsta13 is offline
post #7 of 14 Old 06-05-2013, 1:54 PM Thread Starter
Reputation Power: 7
Yea..I bet turn 7 has a pretty high pucker factor....
My main concern was maybe the suspension..I havent yet took it in to get adjusted to me and my sag...was wondering if that could contribute.
Monolith is offline
post #8 of 14 Old 06-05-2013, 3:02 PM
Quoted: 2 Post(s)
So hard to say exactly what could cause it or what you were feeling. Suspension can cause movement, but so can the road, crosswinds, traffic, etc especially at high speeds.
If you're not used to going that fast, the sensation can certainly overload your senses and make you "feel" a lot more instability than there may actually be and it is surprising how fierce the wind is when upwards of 130. The first time I came close to maxing mine out, it felt like it was really light, almost like it was floating, but that was just after I had gotten my 954 and had never gone that fast. Once I got accustomed to it, I've never felt that again.
Turn 7 is pretty tight coming off the back straight. The kink before it is wide open so it doesn't slow you down. You go from 165 to like 60. It's a great overtaking spot on the brakes. Mid Ohio rocks!
Lobsta13 is offline
post #9 of 14 Old 06-05-2013, 3:59 PM
Reputation Power: 291
Dam thought it was an invite to a buffet
Irish's Blog Page
Hate this Skin
Assalam-o-Alaikum
setanta is offline
post #10 of 14 Old 06-05-2013, 5:37 PM
The aero drag for either side would have suddenly been noticeably different. Mirrors are like sails, it's why racing bikes don't have them. It would drag one way, so you correct, and so on. As that happens any notchiness at all in your steering bearings would come into effect.
amorti is offline
post #11 of 14 Old 06-05-2013, 5:38 PM
If you find yourself in a strong side wind, stick your knee out in the wind side, sounds stupid but it helps balance the bike.
amorti is offline
post #12 of 14 Old 06-05-2013, 11:02 PM Thread Starter
Reputation Power: 7
So the reason it was buffeting so bad was because one mirror was extended and the other folded in due to the wind? That really makes sense...need to replace those mirrors..the left one will not stay tightened...
Appreciate the info.
Monolith is offline
post #13 of 14 Old 06-06-2013, 2:32 AM
Quoted: 4 Post(s)
Reputation Power: 77
If your tall (I'm 6/2) I find my slight bubble screen is worse than the stock screen at high speed, directs the air at my head rather than shoulders and head intensifying the pressure really pushing my helmet back. Have now gone back to stock screen and its better.. If you get a full bubble would prob fix issue but they look horrid! Have you seen the screens on tt bikes they are huge to stop this!
http://youtu.be/2ISgxtQXs9o
My 900RR Winter Project
Lambchops is offline
post #14 of 14 Old 06-06-2013, 6:03 AM
Quoted: 159 Post(s)
Reputation Power: 122
I live in a very windy area, do this all the time.
fj1200rj is offline
Bar end Issue TprRC51 Honda RC51 5 01-05-2013 11:27 PM
1 issue fixed, major issue happened Dudirtt Honda FireBlade 6 04-06-2012 11:35 AM
RC 51 FI Issue SMC1030 Honda RC51 5 06-09-2011 10:00 AM
954 issue Josh5508 Honda FireBlade 1 02-07-2007 11:42 AM
Buffeting an DoubleBubbles? MikeG Honda FireBlade 10 07-15-2004 2:22 PM
