2000 cbr 929rr performance questions. - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 06-07-2013, 9:28 PM Thread Starter
i just bought a 2000 cbr 929rr and was wandering what kind of setup would be good on this bike for performance? this is my first honda and im still a little groggy on knowledge of them. and if i add any certain setup would i still need to get it tuned?
j.sartain7285 is offline
post #2 of 10 Old 06-07-2013, 10:41 PM
Re: 2000 cbr 929rr performance questions.
Wont gain a whole lot, but in my opinion, your best bet would be, to get an exhaust system, get rid of the exhaust servo, get rid of the intake flapper, and get a Power Commander. Without doing engine work, that would get you the most bang for your buck. I done the same thing on my 929, and I noticed a difference
Jdub336 is offline
post #3 of 10 Old 06-07-2013, 11:25 PM
Quoted: 6 Post(s)
Reputation Power: 26
The only performance improvement I need for my 'Blade is an operator upgrade. I do so much want to be able to get some instruction at a place like California Superbike School
ghbzorro is offline
post #4 of 10 Old 06-08-2013, 4:19 AM
Reputation Power: 113
Everybody always goes automatically for exhaust etc. Best upgrades you can make on a bike IMHO, are rider (first and foremost - you can't ride a fast bike fast if you're only capable of slow), brakes, and suspension.
Sky91 is offline
post #5 of 10 Old 06-08-2013, 12:39 PM
Quoted: 3 Post(s)
Reputation Power: 24
954 throttle body's and injectors are a good up grade! is the cheapest! and would give about 5 HP
tweezy666 is offline
post #6 of 10 Old 06-08-2013, 12:40 PM
Quoted: 3 Post(s)
there 6 of these vid's, there good! not sure how many times, I have study these clips!
post #7 of 10 Old 06-08-2013, 12:41 PM
Totally agree ! Good brakes are a must. I've been told that most bikes willl out perform the rider and that in sticky situations if the rider responds correctly the bike will bring you home !
Of course there's exceptions...
'99 CBR900RR - Ride to Live !
Shinyside is offline
post #8 of 10 Old 06-08-2013, 1:37 PM
Quoted: 3 Post(s)
If money was no issue this is the order I would do it!
Tires, brake lines steel, Pc3, race shocks or springs front and back, set up for you. exhaust, 954 TB and injectors, 954 swingarm, brake rotors, steering damper, air filter, quick shifter, 954 motor stuff and bored out to 954.
Some of these cost a lot thou! some of it only really makes a differences to racer! for day to day riding, being rich I would do it this way!
brake lines steel 160$, tires as little as 216$, getting your shocks set up for you 100$ ish, pc3 120$, 954 TB and injectors 100$, exhaust 200$, rotors 200$, air filter, steering damper 300$,
post #9 of 10 Old 06-08-2013, 11:12 PM
I would add lowering the gearing to what everybody else has offered.
post #10 of 10 Old 06-09-2013, 6:57 PM Thread Starter
i appreciate all the feedback! im looking for all around performance. not just power cuz the bike has enough of that and im satisfied with what it has. a little more wouldnt be bad but the suspension and handling is my main concern for now. i wanna know my bike so i can handle it the way it needs to be so go piece at a time starting with the suspension and handling areas.
Dyna tec 2000 ignition performance gains worth the 400.00 daredevil2012 General Discussion 2 02-28-2014 7:52 PM
2000 CBR929RR rectifier questions th3cavalry Honda FireBlade 9 04-09-2013 10:45 AM
01 929rr Questions Nifty929 Honda FireBlade 9 08-22-2011 2:07 PM
2001 Honda 929RR Questions Vanquisher Honda FireBlade 4 02-28-2011 1:13 PM
A few tweaking questions for the pros 929RR kelaog General Discussion 2 08-20-2010 3:34 PM
