02 cbr 954 starting issues - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 06-11-2013, 8:37 AM Thread Starter
Reputation Power: 7
Whats up everyone.
I've seen a few forums from a few years ago with issues like mine but cant seem to find a legit answer. I have a 02 cbr 954 that i turned into a blade rod and I've always had problems with it starting when temp is high. For instance, I can ride to the gas station starts first try and seems fine, but when I shut it off to get gas it gives me problems when I try to restart. Lately its been alot hotter out and for some reason I wouldnt start this morning after sitting in my hot ass garage... Im thinking it could be the starter switch maybe? I replaced the stator about a year ago, removed the power comander 3, and put a new battery in about 6 months ago. It will fire first try most of the time, but like i said it wouldnt start this morning. It almost seems like the battery is running low when you try to crank it, even if ive charged it on a trickle charger all night. Im stumped anyone having the same issue or a solution?
BrandonP954 is offline
post #2 of 9 Old 06-11-2013, 8:58 AM
Re: 02 cbr 954 starting issues
Originally Posted by BrandonP954 View Post
Whats up everyone.
What voltage do you have across the battery, what does it fall to when you press the starter button, and what is it with the engine running?
Does it start better when you boost it off a car battery?
post #3 of 9 Old 06-11-2013, 9:09 AM Thread Starter
Reputation Power: 7
Ill have to mete it when I get home. I had to take my truck to work because it wouldn't start AGAIN this morning :/
post #4 of 9 Old 06-13-2013, 8:40 AM Thread Starter
Reputation Power: 7
Started this morning, but I really doubt it will start when i get off work and its hot as hell outside. Last time it was about 102 outside and when I tried to start it it acted like the battery was dead. Would turn a little but eventually drained the battery. Starter motor maybe? Im thinking the bindings in the motor might be messed up because it only does this when the bike is hot and the coils expand. Any thoughts?
post #5 of 9 Old 06-13-2013, 8:41 AM
Did you try boosting it off a car battery?
post #6 of 9 Old 06-13-2013, 9:42 AM Thread Starter
Reputation Power: 7
I have jumped it before numerous times but usually if I let it cool down like after filling up it will start.
post #7 of 9 Old 06-13-2013, 10:30 AM
So it does start better when the battery is boosted?
Did you check the voltage readings?
post #8 of 9 Old 06-13-2013, 11:38 AM Thread Starter
Reputation Power: 7
The battery was fully charged before I left for work this morning and I'm gonna test it when I get off at 5
post #9 of 9 Old 06-15-2013, 3:49 PM Thread Starter
Reputation Power: 7
So how do I test it?
03 954 starting issues!!!! HELP PLEASE shawn.thompson Honda FireBlade 8 02-23-2018 1:10 PM
954 starting issues ahthud Honda FireBlade 19 04-17-2011 3:19 AM
954 starting issues bigdannyb Honda FireBlade 1 03-23-2010 9:30 PM
starting issues again bencbr Honda CBR400RR 13 02-13-2009 2:13 AM
issues with not starting sometimes bencbr Honda CBR400RR 16 10-31-2008 3:29 AM
