929 clutch adjustment issues - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 06-19-2013, 4:24 AM Thread Starter
Reputation Power: 7
Hi Guys,
I've just fitted some stubby levers to my Blade and now need to adjust the clutch cable at the clutch end - it's pretty much at maximum at the lever. Do I really need to take the whole side fairing off to do the adjustment? Really can't be arsed to do that!
Am I best to have the lever end as tight as I can and then adjust at clutch to give more freeplay?
Also the screw at the lever end looks strange - is the thread supposed to taper nearer the end of the screw? It looks as if some of the thread is broken - I'll take a photo and upload it.
Cheers
Alex
alex350r is offline
post #2 of 7 Old 06-19-2013, 5:19 AM
Re: 929 clutch adjustment issues
Originally Posted by alex350r View Post
Hi Guys,
Cheers
Alex
Back off the handlebar adjuster then take up most of the play at the bottom adjuster. Then use the top adjuster to fine tune the feel.
Do you need to adjust it because the clutch is not fully disengaging, or because the lever is too close to the bar?
post #3 of 7 Old 06-19-2013, 5:22 AM
Reputation Power: 113
If you need to start adjusting the cable that much, it might be worth investing in another. Nothing worse than having to ride home through stop-start traffic with a snapped cable.
Sky91 is offline
post #4 of 7 Old 06-19-2013, 5:23 AM Thread Starter
Reputation Power: 7
Ok thanks - do I need to take off the whole right fairing to do this? or will loosing some of the bolts give me enough access?
Actually I can get the lever far enough away from the bar but the clutch engages too soon. Also I suspect it's not fully disengaging as when I blip the throttle with the clutch pulled in the bike jumps!
alex350r is offline
post #5 of 7 Old 06-19-2013, 6:07 AM
No idea, I haven't had OEM fairings on my for ten years.
Is the lever adjustable?
post #6 of 7 Old 06-19-2013, 9:41 AM Thread Starter
Reputation Power: 7
Well i've just adjusted it up at the clutch end and it seems better - was actually a pretty painless job. It's at the maximum now at the clutch end though so I can't really do any more adjustment. I think i'll order a new cable as it does seem very stiff! Wheres the best place to buy a new cable? local honda dealer?
Cheers
alex350r is offline
post #7 of 7 Old 06-19-2013, 9:57 AM
Honda dealer is probably easiest.
Sky91 is offline
clutch adjustment 929mph Honda FireBlade 23 07-28-2014 4:21 PM
Clutch adjustment question Rhinohuey Honda FireBlade 2 02-20-2012 1:43 AM
clutch adjustment Bike D How To Articles 7 07-11-2010 3:52 PM
clutch adjustment Scruffy Honda FireBlade 2 05-26-2008 4:45 PM
Clutch Adjustment 929 cichlid Honda FireBlade 1 11-25-2004 7:13 AM
