low temperature??? - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 03-07-2004, 2:47 AM Thread Starter
low temperature???
My bike has started reading about 100 degrees below normal in most situations. It begins registering on the guage at about 40 degrees and climbs steady till it averages about 80-85 degrees when running, and then will go up into the 90's when idling for a while. Temperature sensor???
workman1000 is offline
post #2 of 9 Old 03-07-2004, 2:56 AM
Jungleboy's Avatar
Re: low temperature???
Sounds like it thinks its a euro blade as those temperatures would be correct if it was reading in degrees celcius!
2004 1000RR Racebike
www.jungleboyracing.com
Jungleboy is offline
post #3 of 9 Old 03-07-2004, 2:57 AM
The US 'blade can be switched to celcius mode too. Sounds like yours got switched... I don't remember which button does it, but check your owner's manual on how to change it back.
ConqSoft is offline
post #4 of 9 Old 03-07-2004, 3:16 AM Thread Starter
I don't have an owner's manual but I do have a service manual. I don't see anything about switching to celsius in the service manual. Can anyone out there with an owner's manual educate me?
post #5 of 9 Old 03-07-2004, 6:10 AM
No, that is not low temperture. In fact you just explained my temp readings. Those temps are the correct readings for Euro bikes or countries which use the metric system. So, it just means that the temp displayed is as mentioned, degree C and not F as it should be for you.
Athens954 is offline
post #6 of 9 Old 03-07-2004, 9:09 AM
To switch from F to C ore vice-versa hold the right button for 2 sec.
l'timbré is offline
post #7 of 9 Old 03-07-2004, 10:13 AM
OR You can just keep hitting buttons until the desired result is recieved! Who needs directions? Come on....explore! Thats the only way to learn, or to get experience, or to break something...I don't remember, one of those though The right button is the correct button to use though
Tavish is offline
post #8 of 9 Old 03-07-2004, 10:18 AM Thread Starter
Thanks.
post #9 of 9 Old 03-07-2004, 11:20 AM
I take it you don't defuse bombs for a living.
scorch is offline
Normal operating temperature for a 929? pacman Honda FireBlade 18 01-03-2005 12:22 AM
Low prices on Michelin Pilot Race H2 Tires TraumaOne Honda CBR 600 16 01-18-2004 10:26 AM
Hindle low mount owners....Help! slowpoke Honda FireBlade 1 01-15-2004 11:58 AM
How low can you go? Heavy-Dee Road Racing: Professional 18 05-14-2003 8:25 AM
