929 FI light stays on, no blinking, no codes - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 07-03-2013, 9:22 PM Thread Starter
Reputation Power: 11
So today after filling my gas tank my FI light came on and stayed on while riding. The bike runs fine, and if I shut it off and restart it the FI box and red light go away and do not come on until I start moving for a minute or so. My bike doesnt have a servo motor, but I put about 800 miles on it without the light so figured the previous owner bypassed the light when he did the mod. I cannot get any codes to show up either when troubleshooting. Any help is appreciated.
01 929
socci is offline
post #2 of 7 Old 07-04-2013, 2:17 PM Thread Starter
Re: 929 FI light stays on, no blinking, no codes
So according the the manual no blinks or staying lit either means short in service check connector wire, or faulty ecm. Is it ok to ride with one of these faults until I have time to fix it? Also its weird to me that the light will not come on at idle no matter how long it runs. It only comes on while I am a good few minutes into riding. If there was a short or bad ecm wouldnt the light come on at startup?
01 929
socci is offline
post #3 of 7 Old 07-04-2013, 6:47 PM
Reputation Power: 113
Have a look at the diagnostic connector under the seat and make sure it's not been shorted using a paperclip or similar.
Sky91 is offline
post #4 of 7 Old 07-04-2013, 8:19 PM
Reputation Power: 8
id makesure my servo motor was pluged in also
chris954rr is offline
post #5 of 7 Old 07-10-2013, 10:21 PM Thread Starter
The bike does not have a servo motor. Previous owner deleted it. Never had a light until that day, then the next day it was gone. Probably rode it 100 miles with no light except for that one day.
01 929
socci is offline
post #6 of 7 Old 07-11-2013, 6:47 PM
Quoted: 6 Post(s)
Reputation Power: 29
Just double checking,,,, You know the code flashes only start when the stand is down and I think the bikes in neutral?
Mollari is offline
post #7 of 7 Old 07-11-2013, 8:16 PM
Quoted: 120 Post(s)
Reputation Power: 66
Most likely an intermittent short. It is fine and not shorted until you start riding, then it touches a metal surface which shorts it out. I am pretty sure that if it shorts at any time during riding that it will stay on until you shut it back off. Start checking your wiring to see if you can find some bare conductors. Also, as a way to test this, start the bike and bounce it around as much as you can safely do without actually riding it. Try to wobble it side to side (hard), and up and down to see if that triggers it. If it does, that is an immediate indicator that you do have an intermittent short.
RRDemon is offline
91 600 oil light stays on vinceindirt Honda CBR 600 2 05-21-2013 12:03 PM
fi mil light stays on help!!!!!! comokiller Honda FireBlade 15 04-02-2011 11:40 AM
Oil light stays on Addipops Honda FireBlade 12 07-31-2010 8:25 AM
01 cbr 929 mil light stays on tunil Honda FireBlade 4 07-29-2010 2:49 AM
hi all! please help? light blinking on 929! adamerdman Introductions 4 01-27-2010 7:27 PM
