2000 929 won't run - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 07-09-2013, 2:05 PM Thread Starter
2000 929 won't run
Hello , I just bought a 00 929 , it has 175-180 compresion on all 4 cylinders , it has spark at each plug , tried 2 different computers and two different throttle boddies and 2 diff cam pic ups , it will only run with the throttle open about 1/4 and its only about 1200 rpms , it won't rev just dies , it didn't matter where the idle screw is it don't change , I'm lost on what might be the problem right now , any ideas will be tried , when its running the engine sounds good , no knocking of valve noise , thanks
javan1 is offline
post #2 of 6 Old 07-09-2013, 2:10 PM
Re: 2000 929 won't run
Is there coolant running through the wax unit?
post #3 of 6 Old 07-09-2013, 2:28 PM Thread Starter
Coolant is full , what is the wax unit
javan1 is offline
post #4 of 6 Old 07-09-2013, 2:33 PM
It operates the starter valves for cold starting.
Under the throttle bodies.
post #5 of 6 Old 07-09-2013, 2:38 PM Thread Starter
All the hoses r hooked up , I had it running for a good 5 min and water temp was up to 185 f , bike never changed how it would run
javan1 is offline
post #6 of 6 Old 07-10-2013, 12:55 PM
Check that the starter valves are working then, you should be able to feel them if you can't see them.
2000 zx-12r...anybody ever had one?... zingblade General Discussion 3 07-24-2012 10:12 PM
2000 CBR 929 grinchmoster Review My Ride 2 04-21-2011 6:36 PM
2000, 929 Tienie Wanted 1 08-31-2010 4:11 AM
Here's my 2000 929 gr8scape Review My Ride 7 11-18-2008 7:28 PM
ecm 2000 CBR 929 balls Honda FireBlade 3 05-17-2006 3:44 AM
