929 Metal Knocking sound - Honda Motorcycles - FireBlades.org
post #1 of 25 Old 07-10-2013, 4:05 PM Thread Starter
Hi everyone!
I bought a 2000 CBR 929 RED/BLUE/WHITE. The bike needs a lot of TLC
Work I already did:
- Fairing bolt upgrade
- new oil pan ( old one was cracked near the drain bolt)
- front brake new seals and pads.
but now, I noticed a loud metal knock on the upper engine side, side of the rear brake. Near the air box.
I uploaded a YouTube movie, which clearly lets you hear the noise.
The longer the bike runs, and gets hotter, the less frequent the noise appears.
When cold, every 3 - 8 seconds.
When hot, above 85 degrees celcius its every 15 - 30seconds.
I don't notice the sound when riding, might be because the helmet/street is louder than the knocking sound.
I can not hear the noise when engine is revving 4k+, Might be because exhaust note is very loud.
My main suspects are the CCT, because of the CBR 929 CCT history. But the knocking should be louder/more frequent when rpm's rise, right?
Other suspect is fuel pressure, as the noise appears less frequent when engine temp rises.
I can check the CCT but the position of the CCT on a 929 RR is pretty hard to reach.
Hope you guys/girls can help me.
Dafu is offline
post #2 of 25 Old 07-12-2013, 10:19 AM Thread Starter
Re: 929 Metal Knocking sound
Nobody?
Dafu is offline
post #3 of 25 Old 07-12-2013, 1:28 PM
Quoted: 2 Post(s)
Reputation Power: 15
assuming the bike was in neutral with the clutch lever out? does the sound go away if you pull the lever in?
packman5280 is offline
post #4 of 25 Old 07-12-2013, 2:12 PM Thread Starter
No it does not go away when pulling the lever.
Dafu is offline
post #5 of 25 Old 07-12-2013, 4:09 PM
Quoted: 120 Post(s)
Reputation Power: 66
If it is the CCT it will disappear when the engine is revved. The CCT is nothing more than an auto-chain adjuster, these are known for making noise at idle when the system is not fully engaged. I have never heard one knock like that though. I would highly suggest getting it to a bike shop to have them check it out.
RRDemon is offline
post #6 of 25 Old 07-12-2013, 6:03 PM Thread Starter
It might be gone when I am revving hard to tell with all that noise and vibrations. Never noticed it while riding.
What would be the next thing on your suspect list if it is not the CCT?
Dafu is offline
post #7 of 25 Old 07-12-2013, 6:27 PM
Quoted: 2 Post(s)
something with the thermostat perhaps? a stuck spring maybe. or maybe the HTEV servo/cable is loose, or something else in the exhaust. maybe a baffle in the muffler rusted and fell off. or, you left a screw or a rock in the oil pan when you installed it.... just kidding on the last one.
post #8 of 25 Old 07-12-2013, 6:28 PM Thread Starter
Can you please elaborate about "something with the thermostat" ?
Dafu is offline
post #9 of 25 Old 07-12-2013, 6:31 PM
Quoted: 2 Post(s)
thermostats have a spring to hold them closed, then once they warm up they get pushed open by a wax pellet (at least on cars) so if there were something wrong there, perhaps it is opening then snapping back shut? or something mechanically inside it that is binding. i am totally guessing here, reaching quite a bit.
post #10 of 25 Old 07-12-2013, 6:34 PM Thread Starter
I'll check the service manual to see how it works and what moving parts can misbehave. Thanks
Dafu is offline
post #11 of 25 Old 07-12-2013, 11:10 PM
Quoted: 120 Post(s)
I was thinking a rod... but it's not consistent as it would be with a rod. Could be rockers, but again I would think this would be more consistent. Sounds like metal on metal which is never good... Rev it up just a little bit while parked, the CCT should kick in at almost anything above idle. Hell, it could just be a dead CCT chain hitting the cover...
RRDemon is offline
post #12 of 25 Old 07-17-2013, 8:38 AM Thread Starter
A dead CCT chain hitting the cover? Then the engine would not run I guess?
Today I received a new CCT + gasket. But during installation I noticed a deteriorated fuel line which had to be replaced ASAP.
When I receive that new fuel line, I will try and see if the new CCT is able to fix the ticking noise. I'll keep you all posted.
Dafu is offline
post #13 of 25 Old 07-17-2013, 11:34 AM
Reputation Power: 7
or it could of been a stunt bike before and part of the motor wasnt getting oil due to wheelies
954rrRocker is offline
post #14 of 25 Old 08-13-2013, 1:09 AM
Dafu, any update? Is knock present with new CCT? My 929 makes exact same sound since almost new, but not as often. Has 34k mi now, so i'm not worried. It's not the HTEV, since my bike sans HTEV. Sometimes the rpm drops at same time as knock.
There have been posts that sound similar , like this https://www.fireblades.org/forums/honda-fireblade/89613-wierd-clunking-noise-honda-cbr-954rr.html or https://www.fireblades.org/forums/honda-fireblade/93261-929-knocking.html
...2bits
2bitsamile is offline
post #15 of 25 Old 08-13-2013, 8:46 AM Thread Starter
I replaced CCT and knock is still present. I have not noticed rpm drops when he "knocks".
I looked into the oilpan and noticed a lot of metal "dust/grind".
I'm thinking broken cams or something wrong with the valves. The noise comes from the upper right side of the engine. Location of the cam chain,the cams and the valves.
I have no idea what to do next,without spending too much money.
Dafu is offline
Tags
929 , cbr , cct , cold start , noise
Knocking sound when slowing down ChrisC General Discussion 2 07-16-2011 6:06 PM
Knocking Sound Italy37612 General Discussion 8 07-10-2010 11:18 PM
Knocking sound...? temperedtim929 Honda FireBlade 4 09-09-2009 12:50 PM
KNOCKING SOUND ON CBR 954 magicmark General Discussion 12 04-12-2008 5:57 AM
Clanky metal sound fofiffs Honda CBR 600 4 12-24-2007 2:14 PM
