1998 cbr 900 wheel fitment question - Honda Motorcycles - FireBlades.org
post #1 of 13 Old 07-23-2013, 5:47 PM Thread Starter
I have a question that I need some help with.I have a 1998 cbr 900.i was wondering if a set of wheels from a 1997 cbr 900 will fit ? Or if not what the difference is from 97 to 98 is . thanks in advance! Chris.
Chrisg82 is offline
post #2 of 13 Old 07-23-2013, 6:37 PM
Reputation Power: 34
Re: 1998 cbr 900 wheel fitment question
No it won't. Brake disc mounting is totally different. With discs of a carb blackbird and some crafty spacing on the calumets you might or might not make it work.
amorti is offline
post #3 of 13 Old 07-23-2013, 6:39 PM Thread Starter
Ok that settles it,thanks for the reply
Chrisg82 is offline
post #4 of 13 Old 07-24-2013, 5:53 AM
What are calumets Morti?
Tried dictionary.com and still got nowhere :-)
post #5 of 13 Old 07-24-2013, 2:54 PM
argh, iPhone error. IDK how it came out with that, but it's claipers. cipallers. clopiers. meh.
amorti is offline
post #6 of 13 Old 07-24-2013, 3:13 PM
That makes more sense :-)
post #7 of 13 Old 11-21-2013, 11:41 AM Thread Starter
Is that the only issue the calipers??
Chrisg82 is offline
post #8 of 13 Old 11-21-2013, 6:05 PM
The "issue" with the '98/'98 900RR is that they changed the front end, in particular they put the forks wider apart, which changes several other things.
post #9 of 13 Old 11-22-2013, 2:26 PM Thread Starter
So if I were to pick up a set of aftermarket wheels made for up to a 97' I couldn't make them work on my 98'.or if I could what major mods would I need to make?
Chrisg82 is offline
post #10 of 13 Old 11-22-2013, 2:28 PM
I don't think the front would go straight on but the rear is probably the same.
Whatever it takes to make the wheel fit the axle or vice versa, basically change bearings to suit and make up axle and bearing spacers.
Modify the forks/calipers to align them with the discs, and/or modify the discs to make them fit the calipers.
post #11 of 13 Old 11-22-2013, 2:30 PM Thread Starter
Have you seen anyone do this?
Chrisg82 is offline
post #12 of 13 Old 11-22-2013, 2:31 PM
You don't need to "see" it.
You can fit any wheels to any bike.
You can run car wheels front and rear if you want to.
post #13 of 13 Old 11-22-2013, 2:32 PM Thread Starter
Ok,thank you
Chrisg82 is offline
Wheel cross-fitment Sportbike_Mike Honda FireBlade 6 12-03-2012 7:40 PM
929 Rear wheel fitment 929trf Honda FireBlade 1 08-15-2011 12:11 AM
1998 CBR900RR with 17" front wheel: suspension question Jamemoto Honda FireBlade 11 10-25-2009 10:24 AM
FRONT WHEEL FITMENT!!!! kain929 General Discussion 0 04-29-2008 11:57 PM
wheel fitment question DavidGS General Discussion 8 03-18-2004 11:32 AM
