Wire on the back of the Regulator - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 07-31-2013, 5:40 PM Thread Starter
Reputation Power: 9
Gents, whilst I was messing around with my 1996 RRV yesterday I found a thin black wire with Spade connectors on each end mounted behind the Regulator on the Regulators mounting nuts. It was broken and I'm wondering what's it for and is it needed ?
I've read somewhere about Honda Regulator problems is this wire required or something ?
I couldn't see it listed on the Ron Ayers website !!!
Flashhart is offline
post #2 of 7 Old 07-31-2013, 5:43 PM
Reputation Power: 113
Re: Wire on the back of the Regulator
Someone's probably used it as a ground for something at some point.
Sky91 is offline
post #3 of 7 Old 07-31-2013, 5:53 PM Thread Starter
Reputation Power: 9
What doesn't make sense is the bike was bog stock when I bought it with only 1850 miles on it. The wire goes from the back of one nut to the back of the other. I'm referring to the two attachment nuts that hold the rectifier regulator on to the frame.
post #4 of 7 Old 07-31-2013, 6:01 PM
from what you have described, its a ground loop & has no real purpose whatsoever.
Do you have a pic?
Tone is offline
post #5 of 7 Old 07-31-2013, 6:29 PM Thread Starter
Reputation Power: 9
Do you have a pic?
Sorry don't have a pic but it was simply a thin black wire, round spade connector on each end and bolted under the two nuts that the R/R bolts onto. So two bolts throught the R/R mounts and then the nuts on the back with the wire.
Simply I don't need it then ?
post #6 of 7 Old 07-31-2013, 6:34 PM
nah, its not needed at all. Remove it if you wish, wont cause any damage.
Tone is offline
post #7 of 7 Old 07-31-2013, 8:25 PM
Reputation Power: 34
+1
if anything it gives an extra opportunity for the nuts to come loose. Trash it.
While you're in the area you can apply CPU heat paste to the back of the regulator to help it keep cool
amorti is offline
3 wire turn signals to 2 wire LED lights zachsauto Introductions 16 03-27-2014 1:22 PM
954 regulator ground wire? charging issues jacobskeeper Honda FireBlade 0 08-29-2011 10:20 PM
Wire for mid or top end? temperedtim929 Honda FireBlade 1 02-18-2009 11:38 PM
RPM wire? pavetim Honda FireBlade 1 08-07-2006 6:38 PM
2 Wire turnsignal hookup to 3 wire schott Honda CBR 600 5 06-13-2006 8:42 PM
