Need a PC3 map for 929RR - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 08-14-2013, 11:38 PM Thread Starter
Reputation Power: 8
So going through the maps for the 929 and nothing looks even remotely close.
Bike specs:
Two Bro aftermarket header with a MotoGP style can directly connected to the header
Intake flapper removed
Bike has no plastics, so I have no intake ducts
If you have anything remotely close let me know, I can fine tune it
2001 Honda CBR929RR Erion Racing Edition - Current
2001 Honda CBR600RR F4i Stunt bike - Current
2000 Honda CBR929RR Street Fighter - Parted out 8-2014
2006 Kawasaki Ninja 500R - Wadded Up 6-30-12
th3cavalry is offline
post #2 of 12 Old 08-15-2013, 6:08 AM
Re: Need a PC3 map for 929RR
Bike specs:
Have you actually tried some different maps already?
post #3 of 12 Old 08-15-2013, 9:37 AM Thread Starter
Reputation Power: 8
I have not since I'm still putting the bike together.
All the maps I see are for complete non motogp style exhausts and no mention of flapper removed.
post #4 of 12 Old 08-15-2013, 9:54 AM
Reputation Power: 113
The flapper won't make that much of a difference as far as mapping goes. You can always download a map from the site and, as you mention, tune it from there. It's a better baseline than starting from a zero map.
Sky91 is offline
post #5 of 12 Old 08-15-2013, 10:23 AM
I JUST installed my PCIII and downloaded a suggested map from dynojet. it did not state anything about the flapper being removed but i can tell you the bike runs great and has NO flat spots. would it be better with a custom tune... yea probably... would i notice the difference... idk. im happy with how its running right now however.
eagle_lex is offline
post #6 of 12 Old 08-15-2013, 10:44 AM Thread Starter
Reputation Power: 8
Ok. The main thing I'm worried about is my exhaust set up since its header then directly to can with no midpipe. The can I have is RSC Stunt Can.
I know that before I started rebuilding my bike, that with the full two bro system and no flapper, and no intake ducts it was running REALLY rich. Rich enough that was throwing black smoke when cold, and after riding my clothes smelled of exhaust. I was also getting 90 miles per tank lol...
So i'll just research the exhausts listed and find the shortest system available and go from there.
Its a stunt bike, so I'm not wanting to spend 300 bucks for a custom tune...
post #7 of 12 Old 08-15-2013, 10:50 AM
i think anything will "work" considering its a stunt bike im not sure why you would even need a pcIII. maybe it was on the bike when you bought it.. idk. but a stunt bike running rich is going to be the least of that bikes worries! lol
post #8 of 12 Old 08-15-2013, 10:51 AM
just saw your in KY. good to see ya here. PM me. maybe we are close by. although i have not seen another 929 around and def not a 929 stunt bike.
post #9 of 12 Old 08-15-2013, 10:53 AM Thread Starter
Reputation Power: 8
I ride it every day. Its my daily commuter. Its getting all the stunt parts added and going -1/+7 gearing.
post #10 of 12 Old 08-15-2013, 11:02 AM Thread Starter
Reputation Power: 8
plus the thing ran SHITTY below 3500 rpms which could also be affected by a failing cam chain tensioner thats getting replaced with an APE manual after I get my tank back from paint(not really getting painted, but more of a rhino-lined)
post #11 of 12 Old 08-15-2013, 12:03 PM
Quoted: 11 Post(s)
Reputation Power: 57
If you are only getting 90 miles per tank you most likely have a bad Fuel Pressure Regulator. Does your oil smell like gas? A bad FPR will make your bike run worse in low rpm's due to the excess fuel be dumped into #1 & #4 cylinders.
SOLD: 03 CBR954
backdoc is offline
post #12 of 12 Old 08-15-2013, 12:04 PM Thread Starter
Reputation Power: 8
FPR doesn't leak. I've checked it already.
My new 929RR!! stoneysixstring Honda FireBlade 11 06-12-2013 1:20 PM
My new 929RR bigblock390 Introductions 10 11-14-2012 9:15 AM
Parting out my custom 929RR many 929rr and 954rr parts !!!!! superbs929rr For Sale 18 05-07-2011 9:03 PM
CBR 929RR Raime Honda FireBlade 7 03-29-2011 8:23 AM
my 01 929rr mtm864 Review My Ride 12 03-18-2010 9:54 PM
