Need you guys help: 98 cbr900rr - Honda Motorcycles - FireBlades.org
post #1 of 25 Old 08-16-2013, 1:29 PM Thread Starter
hey guys ok heres whats going on my 98 cbr900rr seems to alwasys stall out on my after some sprited riding but after last night it did it all the way home. now the thing is i have gas in the bike it revs up great and then she just dies on me as soon as i leave a stop light.And she will start right back up but after a i get on the throttle she stull. oh she dos have after martket carbs plz help
bigblue98 is offline
post #2 of 25 Old 08-16-2013, 1:52 PM
Reputation Power: 36
Re: Need you guys help: 98 cbr900rr
What kind of carbs? Flatsides? Any other backfiring or pops or anything. Slow acceleration of revs anything?
let me know what carbs are on it. And can be of better help.
Hows exhaust smell clean burn, rich fuely smelling.? Check plugs coloring.
Does it run better or worse when cold. Does or start easy when cold no choke? Or does it have hard start issues even with choke on? Lil more info would help too.
Rubber side down, One wheel to the sky for those who we won't forget. R.I.P homies miss you.
900rrHonda is offline
post #3 of 25 Old 08-16-2013, 2:12 PM
Reputation Power: 7
I would start by breaking down and cleaning the carb very well. Check the plugs while your at it and drain/refill with fresh gas. Check the fuel filter too. my guess is the carb is dirty and gummed up
JohnnySmirk is offline
post #4 of 25 Old 08-16-2013, 2:39 PM
Quoted: 749 Post(s)
Reputation Power: 102
Yeah, explain aftermarket carbs a little more. If they are flat slides then I would suspect that that's not the only mod on the engine. Those carbs were 1200 bucks back in the day and were really only used on race motors (but I know a few guys that had them on the street too). Not trying to insult your intelligence, but do you mean it's been "jetted"? Need more background and history with the bike. Could be the idle is set too low. But flat slide carbs have so many adjustments you could spend weeks trying to dial them in for "drivability". They are meant to be used at the top of the powerband.
IanDoohan is offline
post #5 of 25 Old 08-16-2013, 3:07 PM
This just started happening out of the blue?
What sort of carbs are you running?
Stock airbox and filter?
Is the vacum hose sucking fuel from the fuel tap?
At what RPM are you trying to launch from stop lights?
How much mileage on the spark plugs?
post #6 of 25 Old 08-16-2013, 6:58 PM Thread Starter
Yea sorry guys but they are flat side carbs came with the bike and as for a choke the last owner said it was running with out a choke. But when I took the bike to the dealer because I had I no start problem they put one on the bike and ran good for some time then this problem now, and it dos start and run stronger when cold than when warm. Now it won't even rev out with out bogging then stalling out
post #7 of 25 Old 08-16-2013, 7:26 PM
Quoted: 749 Post(s)
From what I remember flat slides don't have a choke, so the PO was right about that. Now i'm curious how the dealer "put one on"? That might be your problem. Got any Pics?
post #8 of 25 Old 08-16-2013, 7:53 PM Thread Starter
Here's some pics
20130816_183551.jpg‎   20130816_183528.jpg‎
post #9 of 25 Old 08-16-2013, 8:59 PM
Quoted: 749 Post(s)
Here's some pics
Yup 39mm flat slides all right. Still curious about the choke. Do you know how they made it? And if those velocity stacks aren't filtered, with all that dirt and grime I see sound them, that may have something to do with it. The carbs may need to come out and be cleaned, and you may have other internal issues if they are unfiltered.
post #10 of 25 Old 08-16-2013, 11:01 PM
That actually looks like an idle adjuster, i might be looking at the wrong thing but im guessing you turn it not pull it ?
MikeGandy is offline
post #11 of 25 Old 08-16-2013, 11:35 PM
Quoted: 749 Post(s)
Yes exactly right Mike. That's the idle adjustment knob. The white nylon portion needs to be stationary in order for it to work correctly. So still, where is this choke he speaks of???
post #12 of 25 Old 08-17-2013, 3:48 AM
My 39mm FCR's don't have chokes.
post #13 of 25 Old 08-17-2013, 4:37 AM
Quoted: 4 Post(s)
Reputation Power: 77
whats the spec of the engine? porting etc? seems odd to have top end carbs on a stock motor..
http://youtu.be/2ISgxtQXs9o
My 900RR Winter Project
Lambchops is offline
post #14 of 25 Old 08-17-2013, 4:40 AM
At what RPM and thottle position does it start bogging?
post #15 of 25 Old 08-17-2013, 4:40 AM Thread Starter
Yea Mike your right sorry for that that is a pic of the idler screw that's what they replaced, sorry for that guys but the carbs were cleaned at the drealer and I just clean them out again. And yes they are running unfiltered stacks and I'm still having the same problem again bike never had this type of problem before. Will try and post video soon
will 95 cbr900rr forks fit my 96 cbr900rr??? cbr900rr1996 General Discussion 2 09-14-2010 11:57 PM
HEY GUYS,HELLO AGAIN exblader Introductions 12 10-31-2009 9:03 PM
Any other big guys??? 93CB750 General Discussion 21 07-23-2008 8:14 PM
will 2000 cbr900rr rear shock fit 96 cbr900rr? wylier18 Honda FireBlade 0 01-22-2007 2:06 AM
hey guys kelleyj Honda CBR 600 0 10-12-2006 2:25 PM
