929 cams into 954 ? - Honda Motorcycles - FireBlades.org
post #1 of 15 Old 08-19-2013, 2:53 AM Thread Starter
929 cams into 954 ?
i bought a set of cams from a 929 can these go in my 954 motor? are they the same? pros and cons?
cali954rr559 is offline
post #2 of 15 Old 08-19-2013, 3:00 AM
Re: 929 cams into 954 ?
Yes.
954 has 0.26mm and 0.37mm more lift and three degrees more duration on both.
post #3 of 15 Old 08-19-2013, 8:40 PM Thread Starter
so should i use the 929 cams or order the 954 cams? will the 929 cams work or will i loose power?
post #4 of 15 Old 08-20-2013, 2:20 AM
It's your money so that's for you to decide.
Yes, you would lose some power, but not much.
The cam profiles make only a small part of the roughly 10-horsepower advantage the 954 has over the 929 so I'd be surprised if they cost you more than a couple of hp.
That 10hp comes from a combination of the increased capacity and compression, larger throttle bodies, finer injectors, better ECU with finer injector mapping, lighter crank, rods, pistons, alternator rotor and rear wheel - as well as the slightly hotter cam profiles.
post #5 of 15 Old 08-20-2013, 2:21 AM
I guess I should have asked earlier, why are you replacing your cams?
post #6 of 15 Old 08-20-2013, 5:37 AM Thread Starter
i had couple burnt valves so i ordered head with cams off ebay when i looked at those cams they were worn as well as the original ones i had. so i ordered another set and the guy stated they were for 01 929 and 02-03 954 but i dont think they are for the 954 so i ordered another pair today supose to b for 954 with minamal wear so i guess i wait to see condition of lobes on the set i ordered and go from there or should i throw the 929 cams in. im not looking to race this bike i just want it to be the way it should b its got 21k miles
post #7 of 15 Old 08-20-2013, 5:40 AM
Measure the lobes and compare them to the specs in the manual to determine which cams you have.
How worn are these cams?
I haven't seen any measureable wear on modern cams, the steel is bloody hard stuff.
post #8 of 15 Old 08-20-2013, 7:48 PM Thread Starter
36.7mm on ex and 36.74mm on in im not sure on how to measure lift or duration
post #9 of 15 Old 08-20-2013, 7:50 PM
Those are 954 cams then.
post #10 of 15 Old 08-20-2013, 7:59 PM Thread Starter
what do the 929 cams measure
post #11 of 15 Old 08-20-2013, 8:03 PM
36.6mm IN and 36.2mm EX.
What made you think yours were worn?
post #12 of 15 Old 08-20-2013, 8:08 PM Thread Starter
i had couple lobes that were 35.90mm and one that was flat the set i have now looks good i will try out do u recomend locktight on head bolts
post #13 of 15 Old 08-20-2013, 8:11 PM
You don't have a manual for your bike?
Never, ever LokTite head bolts.
You _oil_ the threads and the washers.
post #14 of 15 Old 08-20-2013, 8:14 PM Thread Starter
i got manual off net so i oil threads and washers do i coat cams and lifters when installing i have engine assembly lube w grafite or do i just use motor oil? by the way thankyou for all your input
post #15 of 15 Old 08-20-2013, 8:18 PM
If you're planning to run the engine soon then just coat everything with engine oil. If the engine is going to sit on a shelf for a long while then use a 50/50 mix of moly grease and engine oil.
WTB 954 cams DingDongGo Wanted 2 11-24-2009 2:04 PM
Cams wjdrake21 Honda FireBlade 2 07-23-2009 3:57 AM
Web Cams 93-99 RR cbr900racer77 For Sale 3 04-02-2009 12:48 AM
929 vs 954 (cams) shawdawg17 Honda FireBlade 4 08-31-2008 2:15 PM
HGA cams jmg Honda FireBlade 5 12-28-2005 7:38 PM
