Coolant change - couple of questions - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 08-21-2013, 6:54 AM Thread Starter
Reputation Power: 7
Hi Guys,
I'm giving my blade a service soon and I'm planning to flush and change the coolant while I'm there. Anything I should be aware of? I've already removed the side fairings and the air ducts so I should have access to everything. I read somewhere that it's easier to pull the hoses off rather than undo the radiator drain plug in case it shears in the process? Also how much coolant will I need to refill? I was planning on buying 2 litres but not sure if that will be enough.
Cheers
Alex
alex350r is offline
post #2 of 8 Old 08-21-2013, 6:59 AM
Re: Coolant change - couple of questions
Originally Posted by alex350r View Post
Hi Guys,
Cheers
Alex
You didn't consider getting yourself a manual?
post #3 of 8 Old 08-21-2013, 7:05 AM Thread Starter
Reputation Power: 7
I have a manual - I was simply asking if anyone had any tips from when they had done it.
alex350r is offline
post #4 of 8 Old 08-21-2013, 7:15 AM
The manual doesn't specifiy the coolant capacity?
post #5 of 8 Old 08-21-2013, 7:22 AM Thread Starter
Reputation Power: 7
Sorry I thought you meant Haynes Manual! Ok thanks I'll check my manual and see if it says in there.
Cheers
alex350r is offline
post #6 of 8 Old 08-21-2013, 7:25 AM
Cheers
Haynes and the OEM manuals will specify the capacities. might even be in the Owner's Manual but I'd have to check that.
What sort of bike are you talking about?
post #7 of 8 Old 08-21-2013, 8:15 AM
Reputation Power: 113
Better to pull the hoses IMHO. I've had drain bolts snap before and it's a PITA.
Sky91 is offline
post #8 of 8 Old 08-21-2013, 10:31 AM Thread Starter
Reputation Power: 7
It's a 2001 929 blade and thanks @Sky91 i'll pull the hoses instead
alex350r is offline
Couple of questions I need help with HeadlessHrseman Honda FireBlade 9 01-27-2012 9:02 AM
a couple of questions yotasupra Honda RC51 9 05-10-2008 6:20 AM
Couple of questions on the 929 DasGerminator Honda FireBlade 5 11-18-2006 8:57 PM
A couple of questions for you Nickelii Road Racing: Club / Amateur 10 05-12-2006 9:15 AM
Couple questions here... BlaZin -=929=- General Discussion 17 07-28-2004 5:02 PM
