954rr dies and starts up again. dont know what problem is - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 08-22-2013, 12:14 AM Thread Starter
ok so this is the shimmy
i have a 02 954rr. the bike starts up fine. as soon as i leave my house and get to the corner it dies. it does this really almost anytime i am in low rpms ( slow down to take turns, stop at light ect)
when i am riding on the freeway or somewhere where i am using throttle constantly, the bike runs nice and strong.
i recently had hids put in. and as u may no the 954 has all three lights into one fuse. i initially started with just the high beams as hids and the bike ran fine. when i put in the low beam it started having this issue. i recently unplugged the power to the ballast and it still has this problem.
could this be something with the kill switch? thanks for any advice in advance.
i have read a couple forums and am having some trouble finsing someone with the exact same problem.
k1llapanda is offline
post #2 of 5 Old 08-22-2013, 4:17 AM
Re: 954rr dies and starts up again. dont know what problem is
No MIL flashing on the dash though?
You don't lose the instruments and you don't have to cycle the ignition switch to restart?
Unplug the headlight connectors to confirm that is where the problem is.
What is your idle speed?
post #3 of 5 Old 08-22-2013, 9:59 AM Thread Starter
the only code i get is the servo cuz my exhaust is chopped.
when i try to restart the bike the dash goes out sometimes and il have to flip the kill a couple times and turn the key back and forth occasionally.
i unplugged the low and the problem is still there.
idle around 11-1300.
thanks blade
post #4 of 5 Old 08-22-2013, 10:03 AM
thanks blade
Do the tests of the charging system but I don't think that's the problem, it will be one day though.
Are the battery terminals clean and tight?
Have you checked the grounding junction block buried in the front of the harness? They tend to corrode and come apart.
The kill switch should be always on - if you use it regularly then that may well be the problem.
post #5 of 5 Old 08-22-2013, 10:19 AM Thread Starter
charging system is good.
battery is tight and good
the harness clock ur talking about... is it the yellow box?
i use the kill occasionally but its a **** job on the soldering.
99 cbr starts then dies j_mans01 Honda CBR 600 0 01-13-2012 9:00 PM
Starts w/ choke only, dies w/in 1 minute or if throttled devin707 Honda CBR 600 4 11-23-2010 9:36 PM
2000 CBRF4 STARTS SPUTTERING AND DIES WHEN RIDING AFTER 20MINS. IRDWELDER Introductions 11 08-21-2009 2:07 PM
93 cbr 600 starts hard then runs and dies help honda4life251 Honda CBR 600 3 05-23-2008 9:01 PM
F4I dies short after starts to run Velotrol General Discussion 0 03-27-2007 11:25 PM
