CBR 954 unable to go into first - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 08-30-2013, 8:03 AM Thread Starter
Reputation Power: 11
Came home last night and was unable to get the bike in neutral. Turned it off and managed to do it finally, but then unable to get it into first, can get it into second, but not first. What is the likely problem?
nomadicbiker is offline
post #2 of 6 Old 08-30-2013, 8:52 AM
Re: CBR 954 unable to go into first
With the engine off or running?
Loose shift linkage or rearset?
Clutch cable stretched?
post #3 of 6 Old 08-30-2013, 11:21 AM Thread Starter
Both.
The clutch has been a bit funny of late, will have a look at those over the weekend.
post #4 of 6 Old 08-30-2013, 6:07 PM
did u try just rolling your bike about an inch or two when putting it into first from neutral.....it helps engage good luck
l420I is offline
post #5 of 6 Old 08-30-2013, 6:16 PM
Quoted: 128 Post(s)
Reputation Power: 66
Sometimes the constant-mesh trans doesn't want to switch gears if you stop kind of funny. I have the same issue with my 54 on occasion with it wanting to go into gear, if you let out on the clutch a bit and roll forward a smidge it should pop right into gear or neutral.
If that doesn't work try adjusting the shift linkage. They can occasionally shrink up a little and won't travel far enough to actually engage the gear. How does it downshift from the upper gears?
RRDemon is offline
post #6 of 6 Old 08-30-2013, 6:20 PM
^ i agree with him cause he agrees with me, but it should pop right into gear
l420I is offline
